2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Base 7.0.1.1 tag lost its submodule info
From: Ralph Lange via Core-talk <[email protected]>
To: EPICS Core Talk <[email protected]>
Date: Thu, 31 Jan 2019 10:49:50 +0100
Sorry Han,
There are some particular issues with how git handles (or actually doesn't) checkouts of submodules from the parent module itself, which was one of the reasons to eventually get rid of that setup.
Inside the .gitmodules file, a repository setting of './' (i.e. the parent) is silently translated into the remote URL of the parent repository, so the whole idea of checking out multiple branches from the single local repo is being perverted into cloning multiple copies of the same remote repo, wasting space intead of saving it.
The workaround is to not let git automatically do the submodule init for these three "internal" branches. This has always been that way, I have always been doing this for all my working copies. With that manual local clone of the internal branches, there really is only one copy of the repository on disk.
Here's my log - using ssh for the epics-base module to demonstrate that it also works (my input is bold):
ralph@debian-testing:~$ mkdir TTT; cd TTT
ralph@debian-testing:~/TTT$ git clone -b R7.0.1.1 ssh://[email protected]/epics-base/epics-base.git base-7.0.1.1
Cloning into 'base-7.0.1.1'...
remote: Enumerating objects: 1, done.
remote: Counting objects: 100% (1/1), done.
remote: Total 119076 (delta 0), reused 0 (delta 0), pack-reused 119075
Receiving objects: 100% (119076/119076), 99.26 MiB | 756.00 KiB/s, done.
Resolving deltas: 100% (87164/87164), done.
Note: checking out '37d103f9cd8b05f97bdbd1e26353102e33231960'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b <new-branch-name>
ralph@debian-testing:~/TTT$ cd base-7.0.1.1/
ralph@debian-testing:~/TTT/base-7.0.1.1$ git clone . modules/ca
Cloning into 'modules/ca'...
done.
ralph@debian-testing:~/TTT/base-7.0.1.1$ git clone . modules/database
Cloning into 'modules/database'...
done.
ralph@debian-testing:~/TTT/base-7.0.1.1$ git clone . modules/libcom
Cloning into 'modules/libcom'...
done.
ralph@debian-testing:~/TTT/base-7.0.1.1$ git submodule update --init
Submodule 'modules/ca' (ssh://[email protected]/epics-base/epics-base.git/) registered for path 'modules/ca'
Submodule 'modules/database' (ssh://[email protected]/epics-base/epics-base.git/) registered for path 'modules/database'
Submodule 'modules/libcom' (ssh://[email protected]/epics-base/epics-base.git/) registered for path 'modules/libcom'
Submodule 'modules/normativeTypes' (https://github.com/epics-base/normativeTypesCPP) registered for path 'modules/normativeTypes'
Submodule 'modules/pvAccess' (https://github.com/epics-base/pvAccessCPP) registered for path 'modules/pvAccess'
Submodule 'modules/pvData' (https://github.com/epics-base/pvDataCPP) registered for path 'modules/pvData'
Submodule 'modules/pvDatabase' (https://github.com/epics-base/pvDatabaseCPP) registered for path 'modules/pvDatabase'
Submodule 'modules/pva2pva' (https://github.com/epics-base/pva2pva) registered for path 'modules/pva2pva'
Submodule 'modules/pvaClient' (https://github.com/epics-base/pvaClientCPP) registered for path 'modules/pvaClient'
Cloning into '/home/ralph/TTT/base-7.0.1.1/modules/normativeTypes'...
Cloning into '/home/ralph/TTT/base-7.0.1.1/modules/pvAccess'...
Cloning into '/home/ralph/TTT/base-7.0.1.1/modules/pvData'...
Cloning into '/home/ralph/TTT/base-7.0.1.1/modules/pvDatabase'...
Cloning into '/home/ralph/TTT/base-7.0.1.1/modules/pva2pva'...
Cloning into '/home/ralph/TTT/base-7.0.1.1/modules/pvaClient'...
Submodule path 'modules/ca': checked out '524ceee2c8ce8f8446c46d93b5a467edd14b8cc5'
Submodule path 'modules/database': checked out '610f008529059c7fc1e35896ff0f678b7adcfa6d'
Submodule path 'modules/libcom': checked out '8ce980f6637d85fb1f5a139bab404269734b31bc'
Submodule path 'modules/normativeTypes': checked out 'ba2e1c8a1d1837c8817e14372cccc12f16942200'
Submodule path 'modules/pvAccess': checked out '8c4353bd57dc4e29145792b2b6e2aeeb81c32efe'
Submodule path 'modules/pvData': checked out '07afe3887bc4d6ca921d135eef13d91c9e84a155'
Submodule path 'modules/pvDatabase': checked out 'b26c0ecd713a9c87b891afbfef44d6109e13800a'
Submodule path 'modules/pva2pva': checked out '40014786810c3709c0e14cb179c93cdcfb66f973'
Submodule path 'modules/pvaClient': checked out 'b5291d96196825fd2ce5d7ce47559b1dddf3449e'
So - once you navigate around Git's unwanted behavior - the rest of the process is completely based on the hashes - that are permanent - and does not rely on volatile branch names.
The past has not been changed, no tags have been touched, all original commits are wherever they have been.
In general, I would suggest that you always apply known patches for bugs you find and don't let this keep you from updating.
Looking at 7.0.1.1 and 7.0.2, you deliberately use a version with lower overall quality (more bugs) to avoid applying a critical bugfix patch.
Cheers,
~Ralph
Re: Base 7.0.1.1 tag lost its submodule info Jeong Han Lee via Core-talk
Re: Base 7.0.1.1 tag lost its submodule info Johnson, Andrew N. via Core-talk
Prev: Re: Base 7.0.1.1 tag lost its submodule info Johnson, Andrew N. via Core-talk
Next: Re: Base 7.0.1.1 tag lost its submodule info Jeong Han Lee via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
