Yeah, I already prepared that rtems-toolchain.
My problem what I have/had with the pull-request
was that in my CONFIG_SITE I set
CROSS_COMPILER_TARGET_ARCHS=RTEMS-beatnik
and "beatnik" does not exist at travis.
The travis-build unfortunately does not overwrite this but appends
CROSS_COMPILER_TARGET_ARCHS += RTEMS-pc386-qemu
to the file.
I would only have to delete this entry in my CONFIG_SITE for the 4.9 and 4.10 tests.
Can I do this now on the travis or should I pull a new pull-request with the change in CONFIG_SITE?
> On 6. Mar 2019, at 17:04, Michael Davidsaver <[email protected]> wrote:
> On 3/6/19 3:55 AM, Heinz Junkes via Core-talk wrote:
>> I finally managed to do a pull-request on epics-base for RTEMS-5. I learned that this automatically starts a travis job.
>> I guess I have to change the .ci/travis-build.sh as well. Do I have to make a new pull request afterwards?
>> or can I change the pull request that failed at travis, and if so, how?
> The first (and probably most difficult) step will be making a newer toolchain
> available. The travis ci builds for 4.9 and 4.10 use pre-build binaries from
> https://github.com/mdavidsaver/rsb/releases
> Based on my past experience with the rtems source builder scripts, step one
> is for you to make a copy of all of the source tars, and especially patches,
> you used before they disappear.
smime.p7s
Description: S/MIME cryptographic signature
- Re: pull-request -> travis Michael Davidsaver via Core-talk
- pull-request -> travis Heinz Junkes via Core-talk
<2019>
2025
2026
<2019>
2025
2026
