2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: pull-request -> travis
From: Michael Davidsaver via Core-talk <[email protected]>
To: Heinz Junkes <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 6 Mar 2019 08:59:37 -0800
On 3/6/19 8:23 AM, Heinz Junkes wrote:
> Yeah, I already prepared that rtems-toolchain.
> My problem what I have/had with the pull-request
> was that in my CONFIG_SITE I set
> CROSS_COMPILER_TARGET_ARCHS=RTEMS-beatnik
> and "beatnik" does not exist at travis.
> The travis-build unfortunately does not overwrite this but appends
> CROSS_COMPILER_TARGET_ARCHS += RTEMS-pc386-qemu
> to the file.
> I would only have to delete this entry in my CONFIG_SITE for the 4.9 and 4.10 tests.
> Can I do this now on the travis or should I pull a new pull-request with the change in CONFIG_SITE?
Push this change to the same 7.0 branch in your repo.
You shouldn't need to create a new pull request unless you want to switch
source branch or target branch.
>> On 6. Mar 2019, at 17:04, Michael Davidsaver <[email protected]> wrote:
>> On 3/6/19 3:55 AM, Heinz Junkes via Core-talk wrote:
>>> I finally managed to do a pull-request on epics-base for RTEMS-5. I learned that this automatically starts a travis job.
>>> I guess I have to change the .ci/travis-build.sh as well. Do I have to make a new pull request afterwards?
>>> or can I change the pull request that failed at travis, and if so, how?
>> The first (and probably most difficult) step will be making a newer toolchain
>> available.  The travis ci builds for 4.9 and 4.10 use pre-build binaries from
>> https://github.com/mdavidsaver/rsb/releases
>> Based on my past experience with the rtems source builder scripts, step one
>> is for you to make a copy of all of the source tars, and especially patches,
>> you used before they disappear.
pull-request -> travis Heinz Junkes via Core-talk
Re: pull-request -> travis Michael Davidsaver via Core-talk
Re: pull-request -> travis Heinz Junkes via Core-talk
Prev: Re: pull-request -> travis Heinz Junkes via Core-talk
Next: Jenkins build became unstable: epics-7.0 » linux64 #97 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 07 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
