2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-7.0-win64-test #4
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 11 Mar 2019 17:37:47 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/4/display/redirect>
[...truncated 21.17 KB...]
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/src/O.windows-x64'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/src'>
make -C ./RTEMS test-results
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/RTEMS'>
make -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 test-results
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/RTEMS/O.windows-x64'>
make[4]: Nothing to be done for 'test-results'.
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/RTEMS/O.windows-x64'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/RTEMS'>
make -C ./vxWorks test-results
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/vxWorks'>
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/vxWorks/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/vxWorks/O.windows-x64'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/vxWorks'>
make -C ./test test-results
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/test'>
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/test/O.windows-x64'>
prove --failures --ext .tap --exec "perl -CSD -MExtUtils::Command -e cat" --color epicsUnitTestTest.tap epicsTypesTest.tap epicsInlineTest.tap epicsCalcTest.tap epicsAlgorithmTest.tap epicsMathTest.tap epicsMMIOTest.tap epicsEllTest.tap epicsEnvTest.tap epicsEnvUnsetTest.tap epicsErrlogTest.tap epicsStdioTest.tap epicsStdlibTest.tap epicsSockResolveTest.tap epicsStringTest.tap epicsTimeTest.tap epicsTimeZoneTest.tap epicsThreadTest.tap epicsThreadOnceTest.tap epicsThreadPriorityTest.tap epicsThreadPrivateTest.tap epicsThreadHooksTest.tap epicsThreadPoolTest.tap epicsExitTest.tap epicsTimerTest.tap ringPointerTest.tap ringBytesTest.tap epicsEventTest.tap epicsMutexTest.tap epicsSpinTest.tap epicsAtomicTest.tap macDefExpandTest.tap cvtFastTest.tap macLibTest.tap aslibtest.tap macLib.tap taskwdTest.tap blockingSockTest.tap epicsMessageQueueTest.tap epicsStackTraceTest.tap ipAddrToAsciiTest.tap osiSockTest.tap
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsEnvUnsetTest.tap ........ ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
cvtFastTest.tap .............. ok
macLibTest.tap ............... ok
aslibtest.tap ................ ok
macLib.tap ................... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
All tests successful.
Test Summary Report
epicsMathTest.tap          (Wstat: 0 Tests: 35 Failed: 0)
  TODO passed:   8-9, 11-12, 22-23
Files=42, Tests=4091,  6 wallclock secs ( 0.75 usr +  0.72 sys =  1.47 CPU)
Result: PASS
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/test/O.windows-x64'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom/test'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/libcom'>
make -C ./ca test-results
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca'>
make -C ./configure test-results
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/configure'>
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/configure/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/configure/O.windows-x64'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/configure'>
make -C ./src test-results
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src'>
make -C ./client test-results
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/client'>
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/client/O.windows-x64'>
make[5]: Nothing to be done for 'test-results'.
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/client/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/client'>
make -C ./tools test-results
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/tools'>
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/tools/O.windows-x64'>
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/tools/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/tools'>
make -C ./perl test-results
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/perl'>
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/perl/O.windows-x64'>
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/perl/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/perl'>
make -C ./template test-results
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/template'>
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/template/O.windows-x64'>
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/template/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src/template'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca/src'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/ca'>
make -C ./database test-results
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database'>
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/configure'>
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/configure/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/configure/O.windows-x64'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/configure'>
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src'>
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/tools'>
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/tools/O.windows-x64'>
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/tools/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/tools'>
make -C ./ioc test-results
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/ioc'>
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/ioc/O.windows-x64'>
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/ioc/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/ioc'>
make -C ./std test-results
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/std'>
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/std/O.windows-x64'>
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/std/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/std'>
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/template'>
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/template/O.windows-x64'>
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/template/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src/template'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/src'>
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test'>
make -C ioc/db test-results
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/ioc/db'>
make -C O.windows-x64 -f ../Makefile TOP=../../../.. \
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/ioc/db/O.windows-x64'>
prove --failures --ext .tap --exec "perl -CSD -MExtUtils::Command -e cat" --color dbScanTest.tap dbShutdownTest.tap dbPutLinkTest.tap dbLockTest.tap dbStressTest.tap testdbConvert.tap callbackTest.tap callbackParallelTest.tap dbStateTest.tap dbServerTest.tap dbCaStatsTest.tap dbCaLinkTest.tap scanIoTest.tap dbChannelTest.tap dbChArrTest.tap chfPluginTest.tap arrShorthandTest.tap recGblCheckDeadbandTest.tap testPutGetTest.tap dbStaticTest.tap
dbScanTest.tap ............... ok
dbShutdownTest.tap ........... ok
dbPutLinkTest.tap ............ ok
dbLockTest.tap ............... ok
dbStressTest.tap ............. ok
testdbConvert.tap ............ ok
callbackTest.tap ............. ok
callbackParallelTest.tap ..... ok
dbStateTest.tap .............. ok
dbServerTest.tap ............. ok
dbCaStatsTest.tap ............ ok
dbCaLinkTest.tap ............. ok
scanIoTest.tap ............... ok
dbChannelTest.tap ............ ok
dbChArrTest.tap .............. ok
chfPluginTest.tap ............ ok
arrShorthandTest.tap ......... ok
recGblCheckDeadbandTest.tap .. ok
testPutGetTest.tap ........... ok
dbStaticTest.tap ............. ok
Files=20, Tests=2870,  3 wallclock secs ( 0.69 usr +  0.31 sys =  1.00 CPU)
Result: PASS
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/ioc/db/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/ioc/db'>
make -C ioc/dbtemplate test-results
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/ioc/dbtemplate'>
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/ioc/dbtemplate/O.windows-x64'>
prove --failures --ext .tap --exec "perl -CSD -MExtUtils::Command -e cat" --color msi.tap
msi.tap .. ok
Files=1, Tests=9,  0 wallclock secs ( 0.16 usr +  0.03 sys =  0.19 CPU)
Result: PASS
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/ioc/dbtemplate/O.windows-x64'>
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/ioc/dbtemplate'>
make -C std/rec test-results
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/std/rec'>
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/std/rec/O.windows-x64'>
prove --failures --ext .tap --exec "perl -CSD -MExtUtils::Command -e cat" --color arrayOpTest.tap recMiscTest.tap linkRetargetLinkTest.tap linkInitTest.tap compressTest.tap asyncSoftTest.tap softTest.tap asTest.tap analogMonitorTest.tap scanEventTest.tap regressTest.tap simmTest.tap mbbioDirectTest.tap asyncproctest.tap netget.tap
arrayOpTest.tap ........... ok
recMiscTest.tap ........... ok
linkRetargetLinkTest.tap .. ok
linkInitTest.tap .......... ok
compressTest.tap .......... ok
asyncSoftTest.tap ......... ok
softTest.tap .............. ok
asTest.tap ................ ok
analogMonitorTest.tap ..... ok
scanEventTest.tap ......... ok
regressTest.tap ........... ok
simmTest.tap .............. ok
mbbioDirectTest.tap ....... ok
asyncproctest.tap ......... ok
Bailout called.  Further testing stopped:  No BaseVersion record found
FAILED--Further testing stopped: No BaseVersion record found
make[5]: *** [<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/configure/RULES_BUILD>:367: test-results] Error 1
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/std/rec/O.windows-x64'>
make[4]: *** [<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/configure/RULES_ARCHS>:58: test-results.windows-x64] Error 2
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test/std/rec'>
make[3]: *** [<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/configure/RULES_DIRS>:84: std/rec.test-results] Error 2
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database/test'>
make[2]: *** [<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/configure/RULES_DIRS>:84: test.test-results] Error 2
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules/database'>
make[1]: *** [../configure/RULES_DIRS:84: database.test-results] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/modules'>
make: *** [configure/RULES_DIRS:84: modules.test-results] Error 2
C:\jenkins\win64-2\workspace\epics-base-7.0-win64>exit 2
Build step 'Execute Windows batch command' marked build as failure
Build failed in Jenkins: epics-base-7.0-win64-test #5 APS Jenkins via Core-talk
Build failed in Jenkins: epics-base-7.0-win64-test #3 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-7.0-windows » STATIC,win64-2 #98 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-7.0-win64s-test #5 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-7.0-win64-test #3 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-base-7.0-win64-test #5 APS Jenkins via Core-talk
ANJ, 11 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
