2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-7.0-win64s-test #6
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 11 Mar 2019 21:40:25 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64s-test/6/display/redirect>
[...truncated 14.75 KB...]
perl -CSD dbStressTest.t -tap > dbStressTest.tap
perl -CSD simmTest.t -tap > simmTest.tap
perl -CSD dbStateTest.t -tap > dbStateTest.tap
perl -CSD mbbioDirectTest.t -tap > mbbioDirectTest.tap
perl -CSD dbServerTest.t -tap > dbServerTest.tap
dbRegisterServer: Can't redefine 'one'.
dbRegisterServer: Bad server name 'bad name'
dbRegisterServer: Ignoring 'disabled', per environment
dbUnregisterServer: Servers still active!
dbUnregisterServer: 'toolate' not registered.
dbUnregisterServer: 'no-routines' has no stop() method.
perl -CSD netget.t -tap > netget.tap
perl -CSD asyncproctest.t -tap > asyncproctest.tap
Starting iocInit
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
perl -CSD callbackTest.t -tap > callbackTest.tap
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
perl -CSD dbChArrTest.t -tap > dbChArrTest.tap
Starting iocInit
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
chfConfigParseStart: plugin pvt alloc failed
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
perl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
perl -CSD dbCaLinkTest.t -tap > dbCaLinkTest.tap
perl -CSD testPutGetTest.t -tap > testPutGetTest.tap
perl -CSD dbStaticTest.t -tap > dbStaticTest.tap
perl -CSD scanIoTest.t -tap > scanIoTest.tap
C:\jenkins\win64-2\workspace\epics-base-7.0-win64>make --no-print-directory test-results
make -C ./configure test-results
make -C O.windows-x64-static -f ../Makefile TOP=../.. \
    T_A=windows-x64-static test-results
make[2]: Nothing to be done for 'test-results'.
make -C ./src test-results
make -C ./tools test-results
make -C O.windows-x64-static -f ../Makefile TOP=../../.. \
make[3]: Nothing to be done for 'test-results'.
make -C template/base test-results
make -C O.windows-x64-static -f ../Makefile TOP=../../../.. \
make -C template/ext test-results
make -C ./test test-results
prove --failures --ext .tap --exec "perl -CSD -MExtUtils::Command -e cat" --color Snippets.tap
Snippets.tap .. ok
All tests successful.
Files=1, Tests=29,  0 wallclock secs ( 0.08 usr +  0.03 sys =  0.11 CPU)
Result: PASS
make -C ./modules test-results
make -C ./libcom test-results
make[4]: Nothing to be done for 'test-results'.
make -C ./RTEMS test-results
make -C ./vxWorks test-results
prove --failures --ext .tap --exec "perl -CSD -MExtUtils::Command -e cat" --color epicsUnitTestTest.tap epicsTypesTest.tap epicsInlineTest.tap epicsCalcTest.tap epicsAlgorithmTest.tap epicsMathTest.tap epicsMMIOTest.tap epicsEllTest.tap epicsEnvTest.tap epicsEnvUnsetTest.tap epicsErrlogTest.tap epicsStdioTest.tap epicsStdlibTest.tap epicsSockResolveTest.tap epicsStringTest.tap epicsTimeTest.tap epicsTimeZoneTest.tap epicsThreadTest.tap epicsThreadOnceTest.tap epicsThreadPriorityTest.tap epicsThreadPrivateTest.tap epicsThreadHooksTest.tap epicsThreadPoolTest.tap epicsExitTest.tap epicsTimerTest.tap ringPointerTest.tap ringBytesTest.tap epicsEventTest.tap epicsMutexTest.tap epicsSpinTest.tap epicsAtomicTest.tap macDefExpandTest.tap cvtFastTest.tap macLibTest.tap aslibtest.tap macLib.tap taskwdTest.tap blockingSockTest.tap epicsMessageQueueTest.tap epicsStackTraceTest.tap ipAddrToAsciiTest.tap osiSockTest.tap
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsEnvUnsetTest.tap ........ ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
cvtFastTest.tap .............. ok
macLibTest.tap ............... ok
aslibtest.tap ................ ok
macLib.tap ................... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
Test Summary Report
epicsMathTest.tap          (Wstat: 0 Tests: 35 Failed: 0)
  TODO passed:   8-9, 11-12, 22-23
Files=42, Tests=4091,  6 wallclock secs ( 0.88 usr +  0.69 sys =  1.56 CPU)
Result: PASS
make -C ./ca test-results
make -C ./client test-results
make[5]: Nothing to be done for 'test-results'.
make -C ./perl test-results
make -C ./template test-results
make -C ./database test-results
make -C ./ioc test-results
make -C ./std test-results
make -C ioc/db test-results
prove --failures --ext .tap --exec "perl -CSD -MExtUtils::Command -e cat" --color dbScanTest.tap dbShutdownTest.tap dbPutLinkTest.tap dbLockTest.tap dbStressTest.tap testdbConvert.tap callbackTest.tap callbackParallelTest.tap dbStateTest.tap dbServerTest.tap dbCaStatsTest.tap dbCaLinkTest.tap scanIoTest.tap dbChannelTest.tap dbChArrTest.tap chfPluginTest.tap arrShorthandTest.tap recGblCheckDeadbandTest.tap testPutGetTest.tap dbStaticTest.tap
dbScanTest.tap ............... ok
dbShutdownTest.tap ........... ok
dbPutLinkTest.tap ............ ok
dbLockTest.tap ............... ok
dbStressTest.tap ............. ok
testdbConvert.tap ............ ok
callbackTest.tap ............. ok
callbackParallelTest.tap ..... ok
dbStateTest.tap .............. ok
dbServerTest.tap ............. ok
dbCaStatsTest.tap ............ ok
dbCaLinkTest.tap ............. ok
scanIoTest.tap ............... ok
dbChannelTest.tap ............ ok
dbChArrTest.tap .............. ok
chfPluginTest.tap ............ ok
arrShorthandTest.tap ......... ok
recGblCheckDeadbandTest.tap .. ok
testPutGetTest.tap ........... ok
dbStaticTest.tap ............. ok
Files=20, Tests=2870,  3 wallclock secs ( 0.62 usr +  0.36 sys =  0.98 CPU)
Result: PASS
make -C ioc/dbtemplate test-results
prove --failures --ext .tap --exec "perl -CSD -MExtUtils::Command -e cat" --color msi.tap
msi.tap .. ok
Files=1, Tests=9,  0 wallclock secs ( 0.03 usr +  0.06 sys =  0.09 CPU)
Result: PASS
make -C std/rec test-results
prove --failures --ext .tap --exec "perl -CSD -MExtUtils::Command -e cat" --color arrayOpTest.tap recMiscTest.tap linkRetargetLinkTest.tap linkInitTest.tap compressTest.tap asyncSoftTest.tap softTest.tap asTest.tap analogMonitorTest.tap scanEventTest.tap regressTest.tap simmTest.tap mbbioDirectTest.tap asyncproctest.tap netget.tap
arrayOpTest.tap ........... ok
recMiscTest.tap ........... ok
linkRetargetLinkTest.tap .. ok
linkInitTest.tap .......... ok
compressTest.tap .......... ok
asyncSoftTest.tap ......... ok
softTest.tap .............. ok
asTest.tap ................ ok
analogMonitorTest.tap ..... ok
scanEventTest.tap ......... ok
regressTest.tap ........... ok
simmTest.tap ..............
not ok 438 - dbGetField("mbbi.PACT", 4) -> 1 == 0
not ok 440 - time stamp taken from second pass processing
Failed 2/1176 subtests
mbbioDirectTest.tap ....... ok
asyncproctest.tap ......... ok
netget.tap ................ ok
Test Summary Report
simmTest.tap            (Wstat: 0 Tests: 1176 Failed: 2)
  Failed tests:  438, 440
Files=15, Tests=4320,  3 wallclock secs ( 0.77 usr +  0.28 sys =  1.05 CPU)
Result: FAIL
make[5]: *** [<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64s-test/ws/configure/RULES_BUILD>:367: test-results] Error 1
make[4]: *** [<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64s-test/ws/configure/RULES_ARCHS>:58: test-results.windows-x64-static] Error 2
make[3]: *** [<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64s-test/ws/configure/RULES_DIRS>:84: std/rec.test-results] Error 2
make[2]: *** [<https://jenkins.aps.anl.gov/job/epics-base-7.0-win64s-test/ws/configure/RULES_DIRS>:84: test.test-results] Error 2
make[1]: *** [../configure/RULES_DIRS:84: database.test-results] Error 2
make: *** [configure/RULES_DIRS:84: modules.test-results] Error 2
C:\jenkins\win64-2\workspace\epics-base-7.0-win64>exit 2
Build step 'Execute Windows batch command' marked build as failure
Jenkins build is back to normal : epics-base-7.0-win64s-test #7 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-7.0-windows » STATIC,win32-2 #99 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-7.0-windows » STATIC,win64-2 #99 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-7.0-windows » STATIC,win32-2 #100 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-7.0-win64s-test #7 APS Jenkins via Core-talk
ANJ, 11 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
