2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-7.0-windows » DLL,win32-2 #100
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 11 Mar 2019 22:08:04 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win32-2/100/display/redirect>
Started by upstream project "epics-7.0-windows" build number 100
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win32-2 (win32-x86) in workspace <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win32-2/ws/>
No credentials specified
 > C:/Program Files/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
 > C:/Program Files/Git/cmd/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files/Git/cmd/git.exe fetch --no-tags --force --progress https://git.launchpad.net/epics-base/ +refs/heads/7.0:refs/remotes/origin/7.0 --depth=1
Checking out Revision c93ec231a2b2f13b74f950f39307df9413d0a990 (refs/remotes/origin/7.0)
 > C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
 > C:/Program Files/Git/cmd/git.exe checkout -f c93ec231a2b2f13b74f950f39307df9413d0a990
Commit message: "update PVD and PVA"
 > C:/Program Files/Git/cmd/git.exe rev-list --no-walk d1149a0ba90096b3aa2890029ed9a430216d96ec # timeout=10
 > C:/Program Files/Git/cmd/git.exe remote # timeout=10
 > C:/Program Files/Git/cmd/git.exe submodule init # timeout=10
 > C:/Program Files/Git/cmd/git.exe submodule sync # timeout=10
 > C:/Program Files/Git/cmd/git.exe config --get remote.origin.url # timeout=10
 > C:/Program Files/Git/cmd/git.exe config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
 > C:/Program Files/Git/cmd/git.exe config --get submodule.modules/pvData.url # timeout=10
 > C:/Program Files/Git/cmd/git.exe config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
 > C:/Program Files/Git/cmd/git.exe submodule update --remote modules/pvData
 > C:/Program Files/Git/cmd/git.exe config --get submodule.modules/pvAccess.url # timeout=10
 > C:/Program Files/Git/cmd/git.exe config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
 > C:/Program Files/Git/cmd/git.exe submodule update --remote modules/pvAccess
 > C:/Program Files/Git/cmd/git.exe config --get submodule.modules/normativeTypes.url # timeout=10
 > C:/Program Files/Git/cmd/git.exe config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
 > C:/Program Files/Git/cmd/git.exe submodule update --remote modules/normativeTypes
 > C:/Program Files/Git/cmd/git.exe config --get submodule.modules/pvaClient.url # timeout=10
 > C:/Program Files/Git/cmd/git.exe config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
 > C:/Program Files/Git/cmd/git.exe submodule update --remote modules/pvaClient
 > C:/Program Files/Git/cmd/git.exe config --get submodule.modules/pvDatabase.url # timeout=10
 > C:/Program Files/Git/cmd/git.exe config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > C:/Program Files/Git/cmd/git.exe submodule update --remote modules/pvDatabase
 > C:/Program Files/Git/cmd/git.exe config --get submodule.modules/pva2pva.url # timeout=10
 > C:/Program Files/Git/cmd/git.exe config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > C:/Program Files/Git/cmd/git.exe submodule update --remote modules/pva2pva
Cleaning workspace
 > C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
 > C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
FATAL: Command "C:/Program Files/Git/cmd/git.exe clean -fdx" returned status code 1:
stdout:
stderr: warning: failed to remove bin/win32-x86/ca.dll: Invalid argument
warning: failed to remove bin/win32-x86/Com.dll: Invalid argument
warning: failed to remove bin/win32-x86/dbCore.dll: Invalid argument
warning: failed to remove bin/win32-x86/dbRecStd.dll: Invalid argument
warning: failed to remove bin/win32-x86/pvAccess.dll: Invalid argument
warning: failed to remove bin/win32-x86/pvAccessCA.dll: Invalid argument
warning: failed to remove bin/win32-x86/pvData.dll: Invalid argument
Also:   hudson.remoting.Channel$CallSiteStackTrace: Remote call to win32-2
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
		at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
		at hudson.remoting.Channel.call(Channel.java:955)
		at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:283)
		at com.sun.proxy.$Proxy100.clean(Unknown Source)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl.clean(RemoteGitImpl.java:450)
		at hudson.plugins.git.extensions.impl.CleanCheckout.onCheckoutCompleted(CleanCheckout.java:30)
		at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1270)
		at hudson.scm.SCM.checkout(SCM.java:504)
		at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
		at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
		at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
		at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
		at hudson.model.Run.execute(Run.java:1810)
		at hudson.matrix.MatrixRun.run(MatrixRun.java:153)
		at hudson.model.ResourceController.execute(ResourceController.java:97)
		at hudson.model.Executor.run(Executor.java:429)
hudson.plugins.git.GitException: Command "C:/Program Files/Git/cmd/git.exe clean -fdx" returned status code 1:
stdout:
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2042)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2010)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2006)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1638)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1650)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clean(CliGitAPIImpl.java:828)
	at hudson.plugins.git.GitAPI.clean(GitAPI.java:311)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:929)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:903)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:855)
	at hudson.remoting.UserRequest.perform(UserRequest.java:212)
	at hudson.remoting.UserRequest.perform(UserRequest.java:54)
	at hudson.remoting.Request$2.run(Request.java:369)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-7.0-windows » DLL,win32-2 #99 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-7.0-windows » STATIC,win64-2 #99 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-7.0-windows » STATIC,win32-2 #100 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-7.0-windows » DLL,win32-2 #99 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-7.0-windows » STATIC,win32-2 #99 APS Jenkins via Core-talk
ANJ, 11 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
