2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/make:rpath-origin into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Thu, 28 Mar 2019 21:38:39 -0000
Core group: See Notes below. ANJ to test on Solaris, and rewrite makeRPath into Perl.
Diff comments:
> diff --git a/configure/CONFIG_SITE b/configure/CONFIG_SITE
> index b657f5b..49f82c7 100644
> --- a/configure/CONFIG_SITE
> +++ b/configure/CONFIG_SITE
> @@ -169,10 +169,17 @@ EPICS_SITE_VERSION =
>  GCC_PIPE = NO
>  # Set RPATH when linking executables and libraries.
> -#  Must be either YES or NO.  If you set this to NO you must also provide a
> +#  Must be either YES, NO, or ORIGIN.  If you set this to NO you must also provide a
>  #  way for Base executables to find their shared libraries when they are
>  #  run at build-time, e.g. set the LD_LIBRARY_PATH environment variable.
> +#  ORIGIN is Linux specific.
Needs correcting
>  LINKER_USE_RPATH = YES
> +# Only used when LINKER_USE_RPATH=ORIGIN
> +# The build time root of the relocatable tree.
> +# Linking to libraries under this root directory will be relative.
> +# Linking to libraries outside of this root will be absolute.
> +LINKER_ORIGIN_ROOT = $(INSTALL_LOCATION)
>  # Overrides for the settings above may appear in a CONFIG_SITE.local file
>  -include $(CONFIG)/CONFIG_SITE.local
> diff --git a/modules/database/src/std/softIoc/softMain.cpp b/modules/database/src/std/softIoc/softMain.cpp
> index 8400a65..01ef19b 100644
> --- a/modules/database/src/std/softIoc/softMain.cpp
> +++ b/modules/database/src/std/softIoc/softMain.cpp
> @@ -62,23 +62,59 @@
>  #include "epicsThread.h"
>  #include "epicsExit.h"
>  #include "epicsStdio.h"
> +#include "epicsString.h"
>  #include "dbStaticLib.h"
>  #include "subRecord.h"
>  #include "dbAccess.h"
>  #include "asDbLib.h"
>  #include "iocInit.h"
>  #include "iocsh.h"
> +#include "osiFileName.h"
>  #include "epicsInstallDir.h"
>  extern "C" int softIoc_registerRecordDeviceDriver(struct dbBase *pdbbase);
> -#define DBD_FILE EPICS_BASE "/dbd/softIoc.dbd"
> -#define EXIT_FILE EPICS_BASE "/db/softIocExit.db"
> +#define DBD_BASE "dbd/softIoc.dbd"
> +#define EXIT_BASE "db/softIocExit.db"
> +#define DBD_FILE_REL "../../" DBD_BASE
> +#define EXIT_FILE_REL "../../" EXIT_BASE
> +#define DBD_FILE EPICS_BASE "/" DBD_BASE
> +#define EXIT_FILE EPICS_BASE "/" EXIT_BASE
>  const char *arg0;
>  const char *base_dbd = DBD_FILE;
>  const char *exit_db = EXIT_FILE;
> +static void preparePath(void)
Make it simpler (refactor, remember C++ and similar usage in softIocPVA)
> +    FILE *fp;
> +    char *prefix = epicsGetExecDir();
> +    char *dbd, *exit;
> +    if(!prefix) return;
> +    dbd = (char*)malloc(strlen(prefix) + strlen(DBD_FILE_REL) + 1);
> +    if(dbd) {
> +        dbd[0] = '\0';
> +        strcat(dbd, prefix);
> +        strcat(dbd, DBD_FILE_REL);
> +        printf("Testing '%s'\n", dbd);
Remove printf?
> +        if((fp = fopen(dbd, "rb"))!=NULL) {
> +            fclose(fp);
> +            base_dbd = dbd;
> +    exit = (char*)malloc(strlen(prefix) + strlen(EXIT_FILE_REL) + 1);
> +    if(exit) {
> +        exit[0] = '\0';
> +        strcat(exit, prefix);
> +        strcat(exit, EXIT_FILE_REL);
> +        if((fp = fopen(exit, "rb"))!=NULL) {
> +            fclose(fp);
> +            exit_db = exit;
>  static void exitSubroutine(subRecord *precord) {
>      epicsExitLater((precord->a == 0.0) ? EXIT_SUCCESS : EXIT_FAILURE);
> diff --git a/modules/libcom/src/osi/Makefile b/modules/libcom/src/osi/Makefile
> index ecbf4c2..0352e9f 100644
> --- a/modules/libcom/src/osi/Makefile
> +++ b/modules/libcom/src/osi/Makefile
> @@ -123,6 +123,7 @@ Com_SRCS += osdMonotonic.c
>  Com_SRCS += osdProcess.c
>  Com_SRCS += osdNetIntf.c
>  Com_SRCS += osdMessageQueue.c
> +Com_SRCS += osdgetexec.c
CamelCaseNames?
>  Com_SRCS += devLibVME.c
>  Com_SRCS += devLibVMEOSD.c
> diff --git a/modules/libcom/src/osi/os/Darwin/osdgetexec.c b/modules/libcom/src/osi/os/Darwin/osdgetexec.c
> new file mode 100644
> index 0000000..4e4961c
> --- /dev/null
> +++ b/modules/libcom/src/osi/os/Darwin/osdgetexec.c
> @@ -0,0 +1,50 @@
> +#include <string.h>
> +#include <stdlib.h>
> +#include <mach-o/dyld.h>
> +#define epicsExportSharedSymbols
> +#include <osiFileName.h>
> +char *epicsGetExecName(void)
> +    uint32_t max = 64u;
> +    char *ret = NULL;
> +    while(1) {
> +        char *temp = realloc(ret, max);
> +        if(!temp) {
> +            /* we treat alloc failure as terminal */
> +            free(ret);
> +            ret = NULL;
> +            break;
> +        ret = temp;
> +        /* cf. "man 3 dyld" */
> +        if(_NSGetExecutablePath(ret, &max)==0) {
> +            /* max left unchanged */
> +            ret[max-1] = '\0';
> +            break;
> +        /* max has been updated with required size */
> +    /* TODO: _NSGetExecutablePath() doesn't follow symlinks */
Not a TODO, just a remark.
> +    return ret;
> +char *epicsGetExecDir(void)
> +    char *ret = epicsGetExecName();
> +    if(ret) {
> +        char *sep = strrchr(ret, '/');
> +        if(sep) {
> +            /* nil the charactor after the / */
> +            sep[1] = '\0';
> +    return ret;
> diff --git a/modules/libcom/test/testexecname.c b/modules/libcom/test/testexecname.c
> index 0000000..87be847
> --- /dev/null
> +++ b/modules/libcom/test/testexecname.c
> @@ -0,0 +1,24 @@
> +#include <epicsUnitTest.h>
> +#include <testMain.h>
> +MAIN(testexecname)
> +    testPlan(1);
> +        char *buf = epicsGetExecName();
> +        if(!buf) {
> +            testSkip(1, "epicsGetExecName() not available for this target");
> +        } else {
> +            char *loc = strstr(buf, "testexecname");
> +            testOk(!!loc, "Find \"testexecname\" in \"%s\"", buf);
Test epicsGetExecDir()?
> +    return testDone();
> diff --git a/src/tools/Makefile b/src/tools/Makefile
> index 0df1797..0d0c011 100644
> --- a/src/tools/Makefile
> +++ b/src/tools/Makefile
> @@ -39,6 +39,8 @@ PERL_SCRIPTS += tap-to-junit-xml.pl
>  PERL_SCRIPTS += useManifestTool.pl
>  PERL_SCRIPTS += genVersionHeader.pl
> +PERL_SCRIPTS += makeRPath.py
Needs fixing (ANJ)
>  HTMLS = style.css
>  HTMLS += EPICS/Getopts.html
>  HTMLS += EPICS/Path.html
https://code.launchpad.net/~epics-core/epics-base/+git/make/+merge/359132
Your team EPICS Core Developers is requested to review the proposed merge of ~epics-core/epics-base/+git/make:rpath-origin into epics-base:7.0.
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:timeopt into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: [Merge] ~info-martin-konrad/epics-base:clean-up-msi into epics-base:3.15 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:timeopt into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/make:rpath-origin into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 24 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
