Subject: |
EPICS 7 incompatibility in errMdef.h |
Dirk Zimoch via Core-talk <[email protected]> |
To: |
EPICS Core Talk <[email protected]> |
Date: |
Tue, 2 Apr 2019 16:24:26 +0200 |
[I had originally sent this to tech-talk instead of core-talk by
accident. Sorry for the spam.]
Hi folks,
Today while compiling a driver for EPICS 7 I found an incompatibility.
The function definition errSymbolAdd() (and others) have disappeared
from errMdef.h. Thus when compiling a driver including errMdef.h and
using errSymbolAdd(), I get a compiler warning because of the missing
function prototype.
The prototypes are now in the new header file errSymTbl.h. But simply
including the new file instead is no good solution, because then the
driver does not compile with older EPICS versions any more.
Instead I have use compiler branches based on EPICS versions. That is a
bit inconvenient.
What is the policy about backward compatibility in EPICS 7? Should we
expect more compatibility breaking changes in the future in an attempt
to "move forwards" or will EPICS 7 aim to stay backward compatible for
3rd party code like drivers?
Dirk
- Re: EPICS 7 incompatibility in errMdef.h Dirk Zimoch via Core-talk
- Re: EPICS 7 incompatibility in errMdef.h Johnson, Andrew N. via Core-talk
Jenkins build is still unstable: epics-7.0 » linux32 #110 APS Jenkins via Core-talk
<2019>
2025
2026
Jenkins build is back to normal : epics-base-7.0-win64s-test #15 APS Jenkins via Core-talk
<2019>
2025
2026
ANJ, 08 Apr 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
