2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~anj/epics-base/+git/base-7.0:loadable-err-syms into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
Date: Tue, 02 Apr 2019 17:21:03 -0000
Review: Disapprove
So I discovered that external code built against 3.14 *can* add error symbols at runtime, it just has to do so by calling errSymbolAdd() for each symbol before errlogInit() first gets run, which may be from an explicit call in the startup script, at iocInit, or whenever some code calls one of the errlogPrintf() functions. A C++ static constructor should be fine for registering symbols.
We are now using that approach for the epvxi module, so I am withdrawing this merge proposal.
https://code.launchpad.net/~anj/epics-base/+git/base-7.0/+merge/361344
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: EPICS 7 incompatibility in errMdef.h Michael Davidsaver via Core-talk
Next: [Merge] ~anj/epics-base/+git/base-7.0:loadable-err-syms into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7 incompatibility in errMdef.h Johnson, Andrew N. via Core-talk
ANJ, 03 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
