2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to ensure epicsThread function is running in short-lived environment?
From: Dirk Zimoch via Core-talk <[email protected]>
To: <[email protected]>
Date: Wed, 3 Apr 2019 11:37:40 +0200
Hi Martin,
Try on a system that supports thread priorities (on Linux that requires to run the ioc as root ... or maybe to use "capabilities" which I never found out how to use without being root in the first place) and use a higher priority for the new thread than for the parent thread.
Without priorities, I think the only way would be to use event semaphores like this:
void myThread::run()
  std::cerr << "myThread::run() begin\n";
  epicsThreadSleep(3);
  std::cerr << "myThread::run() end\n";
  epicsEventSignal(done);
int main() {
    myThread t1(0, "foo");
    epicsEventWait(done);
Wait inside the {} before your thread object goes out of context and the destructor is called.
Actually it may also work with putting the epicsThreadSleep(); inside the {}:
int main() {
    epicsThreadSleep(5);
I have not tested anything of the above. So it may or may not work.
Dirk
On 02.04.19 23:35, Konrad, Martin via Core-talk wrote:
I have a bunch of unit tests for support modules that spawn epicsThreads
and tear them down after a very short time. I noticed that although I'm
waiting for the thread to shut down cleanly tests are not reproducible.
In the attached simple code snipped I sometimes see the thread function
running:
$ time ./a.out
myThread::myThread() begin
myThread::myThread() end
myThread::~myThread() begin
myThread::run() end
myThread::~myThread() end
real    0m8.044s
user    0m0.025s
sys     0m0.024s
However, sometimes the destructor gets called so fast that the thread
function doesn't run:
$ time ./a.out
real    0m5.041s
user    0m0.014s
sys     0m0.031s
I'm wondering if there is a way I can ensure run() always runs. I'm
wondering if making the constructor wait until run() actually starts
executing.
Martin
How to ensure epicsThread function is running in short-lived environment? Konrad, Martin via Core-talk
Prev: a question on a commit comment Jeong Han Lee via Core-talk
Next: Re: EPICS 7.0.2.1 release preparation Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: How to ensure epicsThread function is running in short-lived environment? Konrad, Martin via Core-talk
Next: Re: How to ensure epicsThread function is running in short-lived environment? Michael Davidsaver via Core-talk
ANJ, 03 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
