Hi Martin,
On 4/3/19 11:58 AM, Konrad, Martin via Core-talk wrote:
dbScan warning from '1 second' scan thread:
Scan processing averages 1.405 seconds (1.028 .. 2.559).
Over-runs have now happened 10 times in a row.
To fix this, move some records to a slower scan rate.
The IOC is talking to 132 devices using StreamDevice. "scanppl" reports
11408 records on the '1 second' scan list. The VM hosting the IOC is
running happily with 20-30% CPU load on each of its 8 cores. "top -H"
reports 10-15% for the "scan-1" thread.
How heavily loaded are the callback threads cb{Low,Medium,High}?
Naively, I would expect the "scan-1" thread to use 100% of one core (at
least most of the time) when the warning above gets printed. However,
the records in question are being scanned asynchronously which might put
part of the burden on other threads. Nevertheless it's unclear to me why
the "scan-1" thread can't keep up and if there is anything I can do to
improve performance.
Do you have chains of records that are linked together?
What other resources do your devices share that might limit how fast the IOC can communicate with them? How long does it take to "talk" to each device?
I'm also wondering if the work of scanning can be spread out over
multiple threads as suggested by Ralph in [1] - it's unclear to me if
this ever got implemented.
Multiple callback threads was certainly added, and I suspect it might help your situation because the second-half asynchronous processing is probably happening there. For example:
tux% bin/linux-x86_64/softIoc
epics> help callbackParallelThreads
callbackParallelThreads 'no of threads' priority
epics> callbackParallelThreads 2 LOW
epics> callbackParallelThreads 2 HIGH
epics> dbLoadRecords db/softIocExit.db IOC=anj
epics> iocInit
Starting iocInit
## EPICS R7.0.2.1-DEV
## EPICS Base built Mar 20 2019
epics> epicsThreadShowAll
NAME EPICS ID LWP ID OSIPRI OSSPRI STATE
_main_ 0x2037450 13485 0 0 OK
errlog 0x20facd0 14140 10 0 OK
taskwd 0x20fb2e0 14141 10 0 OK
timerQueue 0x20fbd40 14142 70 0 OK
cbLow-0 0x20fc180 14143 59 0 OK
cbLow-1 0x20fc290 14144 59 0 OK
cbMedium 0x20fc6c0 14145 64 0 OK
cbHigh-0 0x20fcaf0 14146 71 0 OK
cbHigh-1 0x20fce50 14147 71 0 OK
dbCaLink 0x20fd3f0 14148 50 0 OK
scanOnce 0x2111050 14149 67 0 OK
scan-10 0x21113b0 14150 60 0 OK
scan-5 0x2111710 14151 61 0 OK
scan-2 0x2111a70 14152 62 0 OK
scan-1 0x2111dd0 14153 63 0 OK
scan-0.5 0x2112130 14154 64 0 OK
scan-0.2 0x2112490 14155 65 0 OK
scan-0.1 0x21127f0 14156 66 0 OK
CAS-TCP 0x211b2b0 14157 18 0 OK
CAS-UDP 0x211b610 14158 16 0 OK
CAS-beacon 0x211b970 14159 17 0 OK
epics>
Note there are two cbLow and cbHigh threads above but only one cbMedium because I didn't ask for two there. You can set the default number of threads used for all priorities at once by omitting the second argument to the
callbackParallelThreads command.
We have not tried to implement parallel periodic scan threads yet, IIRC we suspected there would be more likely to be issues with synchronization or deadlocks in those cases which could affect device or driver support. That's also why we default to having a
single callback thread, but allow you to add more in your startup script.
HTH,
- Andrew
- Excessive scan times for periodic scans Konrad, Martin via Core-talk
Re: Excessive scan times for periodic scans Ralph Lange via Core-talk
Re: Excessive scan times for periodic scans Konrad, Martin via Core-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 03 Apr 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
