2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Excessive scan times for periodic scans
From: Mark Rivers via Core-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, "Konrad, Martin" <[email protected]>
Date: Sun, 7 Apr 2019 22:38:31 +0000
> Also, SCANTIME doesn't seem to change if I remove 99% if the devices/records.
How about the warnings from the scan the 1 second scan thread.  Have you tested how many records or what specific records you need to remove to eliminate those warnings?
From: [email protected] <[email protected]> on behalf of Konrad, Martin via Core-talk <[email protected]>
Sent: Sunday, April 7, 2019 3:43 PM
To: Michael Davidsaver; EPICS Core Talk
Hi Michael,
I like your idea of measuring the scan time using a pair of records with
higher/lower PHAS field. I added the following records (all other
records on my IOC have PHAS=0):
record(ai, "PHAS-1") {
  field(DTYP, "Soft Timestamp")
  field(SCAN, "1 second")
  field(PHAS, "-1")
record(ai, "PHAS1") {
  field(PHAS, "1")
  field(FLNK, "SCANTIME")
record(calc, "SCANTIME") {
  field(INPA, "PHAS-1 NPP MS")
  field(INPB, "PHAS1 NPP MS")
  field(CALC, "1e6*(B-A)")
  field(EGU,  "us")
The result is interesting: SCANTIME reads somewhere between 10 and 100
µs. At the same time I'm getting warnings from the '1 second' scan
thread ("Scan processing averages 1.440 seconds (1.020 .. 2.110)"). Any
idea why the SCANTIME PV and the times in the warning don't line up?
devices/records.
If I monitor a few arbitrary PVs with PHAS 0 I can see them update a
while (for example ~60 ms or ~200 ms) after PHAS1 processes. This
confirms that my records finish processing asynchronously.
Is the scan thread measuring the time until the last asynchronous PV has
received its callback?
Thanks a lot,
Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Excessive scan times for periodic scans Konrad, Martin via Core-talk
Re: Excessive scan times for periodic scans Konrad, Martin via Core-talk
Prev: Re: Excessive scan times for periodic scans Konrad, Martin via Core-talk
Next: Jenkins build is back to normal : epics-base-7.0-win64s-test #15 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: Excessive scan times for periodic scans Ralph Lange via Core-talk
ANJ, 11 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
