Subject: |
[Bug 1824277] Re: Regression in calcout setting constant links at runtime |
Andrew Johnson via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 19 Apr 2019 18:32:40 -0000 |
We could change the code for constant links so they return a value from
their lset::getValue() method (currently that routine exists but just
returns 0). The string-to-number conversion result could be cached so
this doesn't have to be done every time, but this could break any
existing databases that provide an initial value using a constant link
and later do puts to update the related value field.
I guess we could avoid that by coding getValue() so it would only return
a value the first time it's called after the link has been set, and then
only if the loadScalar(), routine that gets called from
recGblInitConstantLink() API hasn't already been called.
However a lot of older code that reads links doesn't actually call
dbGetLink() when the link type is constant (e.g. devAiSoft.c). I removed
a lot of those checks from Base already since they aren't needed, but
many probably still remain, and that pattern or its equivalent is
probably universal in the synApps record types. I just found it in
aCalcout, sCalcout, sseq and transform in the calc module, although not
in swait. The code in those records is going to need updating to not
break if someone gives them a JSON_LINK, but they should continue to
work with just the older link types.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1824277
Title:
Status in EPICS Base:
In Progress
Status in EPICS Base 7.0 series:
In Progress
Bug description:
With the 3.15 branch, writing a literal number to a calcout.INP[A-L]
field causes the corresponding [A-L] field to be set to that number.
This works because the calcout record marks the INP fields as
special(SPC_MOD) and the calcout::special() routine calls
recGblInitConstantLink() to initialize the corresponding [A-L] field
from the new link string. I suspect that a number of the synApps
record types (transform, scalc, acalc etc.) probably use this same
technique.
Keenan Lang reported that this doesn't currently work on the 7.0
branch; the value in the [A-L] field doesn't change, which I have
confirmed.
This use of special() to reinitialize constant links is unusual,
normally putting a literal into a link field after record
initialization has no effect, but someone who worked on the calcout
record discovered this way to get it to work.
I think I know what's going on and how to fix it (change
dbPutFieldLink() to call dbAddLink() before the second call to
dbPutSpecial()), but I need to check that this won't break other
cases.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1824277/+subscriptions
Re: Support for Google Test in EPICS base / modules? Ralph Lange via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Andrew Johnson via Core-talk
<2019>
2025
2026
[Bug 1824277] Re: Regression in calcout setting constant links at runtime Ben Franksen via Core-talk
<2019>
2025
2026
