Subject: |
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 |
Keenan Lang via Core-talk <[email protected]> |
To: |
Andrew Johnson <[email protected]> |
Date: |
Tue, 23 Apr 2019 14:59:45 -0000 |
Then I guess it's up to you guys how important it is to have this fix. Do you think you are likely to switch between links and constant values in user calculations? If you aren't switching between the two, you can just change the A-L fields directly.
https://code.launchpad.net/~anj/epics-base/+git/base-7.0/+merge/366247
Your team EPICS Core Developers is requested to review the proposed merge of ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0.
- [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Andrew Johnson via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 rivers via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Mooney, Tim M. via Core-talk
<2019>
2025
2026
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Lang, Keenan C. via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Keenan Lang via Core-talk
<2019>
2025
2026
