2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0
From: "Lang, Keenan C. via Core-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "Mooney, Tim M." <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 23 Apr 2019 16:23:21 +0000
As far as I can tell, all the screens in synApps that use these records have both input and value editable. There are screens that only have the input fields editable, but those are all local to the IOC.
Sent: Tuesday, April 23, 2019 10:57:15 AM
To: Lang, Keenan C.; Mooney, Tim M.; mp+[email protected]; [email protected]
Hi Keenan,
Does synApps have GUI screens that have a text-entry widget for the INP fields but only a text-display widget for the corresponding value field on these record types? That's the other case I'm most concerned about.
- Andrew
On 4/23/19 10:41 AM, Lang, Keenan C. wrote:
From a scan of our IOC's, it crops up in user calcs, pid calculations and limits, slit transforms, bpm calculations, cmdReply formatting, shutter arming, and a database for fastshutter limits.
Sent: Tuesday, April 23, 2019 10:11:53 AM
To: Johnson, Andrew N.; mp+[email protected]; Lang, Keenan C.; [email protected]
>>What is the bug?
>Record types that are based off of calcout can no longer have a constant value written to their input fields and have the >value of the correct data field change. For example, writing '5' to a calcout's INPA field no longer changes the A field to >5. This affects the calcout, aCalcout, sCalcout, transform, and luascript records.
I'm sure I've never written a database that relies on this behavior.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] <[email protected]> on behalf of Keenan Lang via Core-talk <[email protected]>
Sent: Tuesday, April 23, 2019 9:43 AM
>Keenan Lang is working to release synApps 6.1 by the end of May (see his question at https://github.com/epics-modules/iocStats/issues/33#issuecomment-484995327), but I don't know if that is intended to support EPICS 7
I don't think this release will officially support EPICS 7, but I am definitely going to try to start getting all of our code compliant with newer versions. That's what ended up finding this issue as I was updating some of my own code for the changes to links.
>I understand this seems like a rush, but a synApps release strikes me as a good reason to try and get this fix included.
Since the whole of synApps isn't likely to use EPICSv7 at least for the next year or more, there's not really a rush. The only IOC's going in that use it will be for specific areaDetector cameras and they don't really use the record types affected.
>What is the bug?
Record types that are based off of calcout can no longer have a constant value written to their input fields and have the value of the correct data field change. For example, writing '5' to a calcout's INPA field no longer changes the A field to 5. This affects the calcout, aCalcout, sCalcout, transform, and luascript records.
https://code.launchpad.net/~anj/epics-base/+git/base-7.0/+merge/366247
Your team EPICS Core Developers is requested to review the proposed merge of ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0.
[Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Andrew Johnson via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Keenan Lang via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Mooney, Tim M. via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Lang, Keenan C. via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Johnson, Andrew N. via Core-talk
Prev: RE: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 rivers via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Keenan Lang via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 23 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
