2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0
From: Keenan Lang via Core-talk <[email protected]>
Date: Tue, 23 Apr 2019 14:43:53 -0000
>Keenan Lang is working to release synApps 6.1 by the end of May (see his question at https://github.com/epics-modules/iocStats/issues/33#issuecomment-484995327), but I don't know if that is intended to support EPICS 7
I don't think this release will officially support EPICS 7, but I am definitely going to try to start getting all of our code compliant with newer versions. That's what ended up finding this issue as I was updating some of my own code for the changes to links.
>I understand this seems like a rush, but a synApps release strikes me as a good reason to try and get this fix included.
Since the whole of synApps isn't likely to use EPICSv7 at least for the next year or more, there's not really a rush. The only IOC's going in that use it will be for specific areaDetector cameras and they don't really use the record types affected.
>What is the bug?
Record types that are based off of calcout can no longer have a constant value written to their input fields and have the value of the correct data field change. For example, writing '5' to a calcout's INPA field no longer changes the A field to 5. This affects the calcout, aCalcout, sCalcout, transform, and luascript records.
https://code.launchpad.net/~anj/epics-base/+git/base-7.0/+merge/366247
Your team EPICS Core Developers is requested to review the proposed merge of ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0.
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 rivers via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Mooney, Tim M. via Core-talk
[Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Andrew Johnson via Core-talk
Prev: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 rivers via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 23 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
