2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0
Date: Tue, 23 Apr 2019 11:36:34 -0000
> The bug hasn't affected many users because there hasn't been a release of synApps for EPICS 7 yet, and it's the synApps users who will see and complain about it.
I have been running 7.0.2.2 with synApps for 2 APS run cycles now.  What is the bug?
From: [email protected] <[email protected]> on behalf of Andrew Johnson via Core-talk <[email protected]>
Sent: Monday, April 22, 2019 11:40 PM
To: Andrew Johnson
There should be no change to the behavior of writing to the related value field, which for the calcout isn't marked as special although it is pp so doing so does trigger record processing. Nothing in that chain of processing has been touched though, it's only dbPutFieldLink() that I've modified, the routine that handles puts to a link field. However I just added a couple of testdbPutFieldOk() calls, writing to the two input-value fields that have const INP links.
The fix may slightly alter the code path taken anytime something writes to a link field at runtime, ai.INP fields included, but in most cases there should be no change to the result. It is unusual for a link field to be marked special, and in Base the calcout is the only type which has any special links.
There are a few references to PV_LINK in the epics-modules repo's, but I think you're right that most code won't normally see plink->type == PV_LINK; the only time that should happen with this fix is in a dsxt::add_record() routine where the link type in the device() entry in the DBD file is given as CONSTANT (which means "or DB/CA/PV/JSON LINK").
The bug hasn't affected many users because there hasn't been a release of synApps for EPICS 7 yet, and it's the synApps users who will see and complain about it. Keenan Lang is working to release synApps 6.1 by the end of May (see his question at https://github.com/epics-modules/iocStats/issues/33#issuecomment-484995327), but I don't know if that is intended to support EPICS 7 - synApps 6.0 was aimed at Base-3.15.5. If we're planning to merge other major changes after 7.0.2.2 that could preclude us putting out a patch release for this bug-fix unless we start a release branch.
I understand this seems like a rush, but a synApps release strikes me as a good reason to try and get this fix included.
https://code.launchpad.net/~anj/epics-base/+git/base-7.0/+merge/366247
Your team EPICS Core Developers is requested to review the proposed merge of ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0.
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Andrew Johnson via Core-talk
Prev: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Keenan Lang via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 23 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
