2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: "Lang, Keenan C." <[email protected]>, "Mooney, Tim M." <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 23 Apr 2019 15:57:15 +0000
Hi Keenan,
Does synApps have GUI screens that have a text-entry widget for the INP fields but only a text-display widget for the corresponding value field on these record types? That's the other case I'm most concerned about.
- Andrew
On 4/23/19 10:41 AM, Lang, Keenan C. wrote:
From a scan of our IOC's, it crops up in user calcs, pid calculations and limits, slit transforms, bpm calculations, cmdReply formatting, shutter arming, and a database for fastshutter limits.
Sent: Tuesday, April 23, 2019 10:11:53 AM
To: Johnson, Andrew N.; mp+[email protected]; Lang, Keenan C.; [email protected]
>>What is the bug?
>Record types that are based off of calcout can no longer have a constant value written to their input fields and have the >value of the correct data field change. For example, writing '5' to a calcout's INPA field no longer changes the A field to >5. This affects the calcout, aCalcout, sCalcout, transform, and luascript records.
I'm sure I've never written a database that relies on this behavior.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] <[email protected]> on behalf of Keenan Lang via Core-talk <[email protected]>
Sent: Tuesday, April 23, 2019 9:43 AM
>Keenan Lang is working to release synApps 6.1 by the end of May (see his question at https://github.com/epics-modules/iocStats/issues/33#issuecomment-484995327), but I don't know if that is intended to support EPICS 7
I don't think this release will officially support EPICS 7, but I am definitely going to try to start getting all of our code compliant with newer versions. That's what ended up finding this issue as I was updating some of my own code for the changes to links.
>I understand this seems like a rush, but a synApps release strikes me as a good reason to try and get this fix included.
Since the whole of synApps isn't likely to use EPICSv7 at least for the next year or more, there's not really a rush. The only IOC's going in that use it will be for specific areaDetector cameras and they don't really use the record types affected.
>What is the bug?
Record types that are based off of calcout can no longer have a constant value written to their input fields and have the value of the correct data field change. For example, writing '5' to a calcout's INPA field no longer changes the A field to 5. This affects the calcout, aCalcout, sCalcout, transform, and luascript records.
https://code.launchpad.net/~anj/epics-base/+git/base-7.0/+merge/366247
Your team EPICS Core Developers is requested to review the proposed merge of ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0.
RE: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 rivers via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Lang, Keenan C. via Core-talk
[Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Andrew Johnson via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Keenan Lang via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Mooney, Tim M. via Core-talk
Prev: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 Lang, Keenan C. via Core-talk
Next: RE: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 23 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
