2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1824277] Re: Regression in calcout setting constant links at runtime
From: Ralph Lange via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 23 Apr 2019 17:11:49 -0000
I think that the consistency I would like to see is between DOL/VAL with
OMSL=closed_loop and INPx/x in the calc class of records.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1824277
Title:
Status in EPICS Base:
  In Progress
Status in EPICS Base 7.0 series:
  In Progress
Bug description:
  With the 3.15 branch, writing a literal number to a calcout.INP[A-L]
  field causes the corresponding [A-L] field to be set to that number.
  This works because the calcout record marks the INP fields as
  special(SPC_MOD) and the calcout::special() routine calls
  recGblInitConstantLink() to initialize the corresponding [A-L] field
  from the new link string. I suspect that a number of the synApps
  record types (transform, scalc, acalc etc.) probably use this same
  technique.
  Keenan Lang reported that this doesn't currently work on the 7.0
  branch; the value in the [A-L] field doesn't change, which I have
  confirmed.
  This use of special() to reinitialize constant links is unusual,
  normally putting a literal into a link field after record
  initialization has no effect, but someone who worked on the calcout
  record discovered this way to get it to work.
  I think I know what's going on and how to fix it (change
  dbPutFieldLink() to call dbAddLink() before the second call to
  dbPutSpecial()), but I need to check that this won't break other
  cases.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1824277/+subscriptions
Prev: [Bug 1824277] Re: Regression in calcout setting constant links at runtime Ben Franksen via Core-talk
Next: [Bug 1824277] Re: Regression in calcout setting constant links at runtime Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 23 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
