2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj)
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 02 May 2019 16:59:42 -0000
> Would make delete these as incomplete intermediate files on error?
The compiler isn't returning an error status though, it just doesn't
seem to be creating the output file, or at least not the one we're
asking for. For example from the last build that failed (-256) before
Ralph fixed it, here's the build for ccl.c:
mingw32-make[3]: Entering directory 'C:/projects/epics-base-5e851/src/libCom/O.windows-x64-mingw'
gcc  -D_MINGW -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/WIN32 -I../../../include -o ccl.obj -c ../../../src/libCom/flex/ccl.c
mingw32-make[3]: Leaving directory 'C:/projects/epics-base-5e851/src/libCom/O.windows-x64-mingw'
Then later when make tries to use ccl.obj it just gives:
mingw32-make[3]: *** No rule to make target 'ccl.obj', needed by
'e_flex.exe'.  Stop.
Hmm, since the appveyor-prepare.bat script installs my Make-4.1 for all builds (Make-4.2.1 is also available), why don't the mingw builds use it? The above messages show that they're using mingw32-make, confirmed by the appveyor-make.bat file.
@Ralph  I see this is using an older ActiveState Perl, is that configurable somehow? The latest StrawberryPerl packages (available through Chocolatey) install GNU Make-4.2.1 (named "gmake") and gcc as well, so they provide everything we need for a MinGW build. That's what I'm using here and had no problems with.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1827225
Title:
Status in EPICS Base:
  Fix Committed
Status in EPICS Base 3.15 series:
  Fix Committed
Status in EPICS Base 7.0 series:
  Fix Committed
Bug description:
  It looks like the epicsTempName() commit (6201d37 * 3.15) broke the
  mingw builds.
  E.g. on AppVeyor
  mingw32-make[4]: Leaving directory 'C:/projects/epics-base/modules/libcom/src/O.win32-x86-mingw'
  mingw32-make[4]: *** No rule to make target 'epicsTempFile.obj', needed by 'e_flex.exe'.  Stop.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1827225/+subscriptions
[Bug 1827225] [NEW] epicsTempName() commit breaks mingw builds Ralph Lange via Core-talk
Prev: Build completed: EPICS Base base-3.15-390 AppVeyor via Core-talk
Next: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj) mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj) mdavidsaver via Core-talk
ANJ, 02 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
