Subject: |
Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 |
Andrew Johnson via Core-talk <[email protected]> |
To: |
mdavidsaver <[email protected]> |
Date: |
Fri, 03 May 2019 19:21:23 -0000 |
@Keenan: It isn't the "on" command itself I was thinking about so much as the effect that it has, which is to save the "what to do if there's an error" instruction from it and then later do that thing if a command returns an error status. Since a lua "iocsh.cmd(args)" statement ends up calling the same cmd_callFunc() that iocsh does (which returns void), lua doesn't see any error status either, so the only way to know whether the command flagged an error or not would be to ask iocsh if iocshSetError() was called, hence your need for an iocshGetError() routine.
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/366876
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
- [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 mdavidsaver via Core-talk
Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 Keenan Lang via Core-talk
Build failed: EPICS Base base-3.15-392 AppVeyor via Core-talk
<2019>
2025
2026
<2019>
2025
2026
