2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~info-martin-konrad/epics-base:dont-nuke-global-cac-thread-id-in-exit-handler into epics-base:3.15
From: Martin Konrad via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 06 May 2019 17:55:37 -0000
Oops, of course you're right. I guess taking out the epicsThreadPrivateDelete() call is not really an option either because then the object is leaked...
I guess the right approach would be to use a shared pointer to get it cleaned up when it's not used anymore. But that would obviously break the interface (not sure if we can avoid this here, though). Any thoughts?
https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+merge/366996
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
[Merge] ~info-martin-konrad/epics-base:dont-nuke-global-cac-thread-id-in-exit-handler into epics-base:3.15 Martin Konrad via Core-talk
Prev: Re: [Merge] ~info-martin-konrad/epics-base:dont-nuke-global-cac-thread-id-in-exit-handler into epics-base:3.15 mdavidsaver via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-sol #187 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~info-martin-konrad/epics-base:dont-nuke-global-cac-thread-id-in-exit-handler into epics-base:3.15 mdavidsaver via Core-talk
ANJ, 06 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
