2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~info-martin-konrad/epics-base:dont-nuke-global-cac-thread-id-in-exit-handler into epics-base:3.15
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 06 May 2019 18:18:03 -0000
Yes, ref. counting would probably be the best way to avoid an exit handler here.  I think this could be done with an atomic inc. in ca_context_create() and dec. in ca_context_destroy().
And then I notice that caClientContextIdOnce in access.cpp is already being leaked...  So maybe just remove "cacExitHandler()"?  This would be far from the only one-time leak in Base.
https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+merge/366996
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
[Merge] ~info-martin-konrad/epics-base:dont-nuke-global-cac-thread-id-in-exit-handler into epics-base:3.15 Martin Konrad via Core-talk
Prev: Build failed in Jenkins: epics-base-3.15-sol #187 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-7.0-win64-test #29 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~info-martin-konrad/epics-base:dont-nuke-global-cac-thread-id-in-exit-handler into epics-base:3.15 Martin Konrad via Core-talk
Next: Re: [Merge] ~info-martin-konrad/epics-base:dont-nuke-global-cac-thread-id-in-exit-handler into epics-base:3.15 Andrew Johnson via Core-talk
ANJ, 06 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
