Subject: |
Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 |
Dirk Zimoch via Core-talk <[email protected]> |
To: |
mdavidsaver <[email protected]> |
Date: |
Fri, 10 May 2019 14:59:52 -0000 |
> I hadn't come across https://github.com/raspberrypi/tools previously. Having
> seen it, I don't think I would ever use it!
> Judging by the (3 year old) commit message, these binaries are from a
> crosstool-ng built, not the native raspbian. ABI mis-matches with the raspian
> toolchain are to be expected.
There is a comment about readline in the file.
> fyi. seeing linking issues involving libtinfo.so is a sign of mixing debian
> and non-debian builds of readline.
> If you use this toolchain then imo. full static linking (including libc) is a
> must!
> If interop with raspbian libs is desirable, then I'd suggest looking at QEMU
> user mode emulation to run the hosted toolchain.
> https://wiki.debian.org/RaspberryPi/qemu-user-static
This was the "official" cross tool chain, AFAIK.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/367256
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0.
- Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 mdavidsaver via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Andrew Johnson via Core-talk
<2019>
2025
2026
<2019>
2025
2026
