2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Fri, 10 May 2019 14:58:01 -0000
> Do you have references to upstream bug reports?
> I've never encountered problems like this with the hosted compiler.
What problem? This is no bugfix. I just wanted to share my setup to cross-compile for raspberryPi. Maybe it is useful for others wanting to use EPICS on a pi.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/367256
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 mdavidsaver via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 10 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
