2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Mon, 13 May 2019 19:51:49 -0000
Weird, looks like a Launchpad bug. I just changed Launchpad's "default branch" setting for that repo to be refs/heads/as-hostname although doing that didn't trigger any updates. It was set to refs/heads/master but that branch doesn't actually exist, which might be why LP got confused. I'm about to push a change expanding the Release Notes entry in the hopes that a commit to the repo's default branch might trigger Launchpad to wake up; we'll see whether it does shortly.
Question: I think we said that if a host-name cannot be found, this will cause the IOC to start up with all access disabled. Is this the behavior that we actually want? Wouldn't it be better to allow other hosts that can be resolved to still connect? I suspect our operational ASC files have any number of no-longer-valid host names in them, and here the act of removing a long-disused host name from our DNS is something that could our IT group might do at any time, so it shouldn't prevent our control system from starting up (frankly that would be an operational nightmare). If you change this behavior you should also adjust the Release Note to match (new consequence #2).
https://code.launchpad.net/~epics-core/epics-base/+git/asLib/+merge/358822
Your team EPICS Core Developers is requested to review the proposed merge of ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0.
Prev: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 20 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
