2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 13 May 2019 22:11:17 -0000
I heard back from Pete Jemian, who wrote:
----------------------- 8< -----------------------
Agree that Dirk references the official RPi tools for cross-compile.  I have very little experience with getting that tool chain to work and only rely on native builds for EPICS base.  (Those are easy and do not require any custom files.)  The abhiTronix/raspberry-pi-cross-compilers repo is very new (August 2018) with one contributor.  Haven't tried this yet.  This tool chain might be much easier to assemble than the official one.
The proposed changes benefit those who use cross-compilers for the RPi. If merged, the changes should not affect native builds.
I like Michael's suggestion that a lot of this information might make more sense as a Wiki, blog or tech-talk post. Updating it then wouldn't have to synchronize with Base releases.
You might also consider splitting your CONFIG_SITE file into CONFIG_SITE.linux-x86.raspbian-arm and CONFIG_SITE.linux-x86_64.raspbian-arm where you would put all the parts specific to a 32-bit host into the first file and the 64-bit parts into the second.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/367256
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Andrew Johnson via Core-talk
Next: [Bug 1722535] Re: 'make distclean' inside a submodule Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 14 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
