2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 14 May 2019 09:27:38 -0000
The 32 bit tool chains work on 64 bit hosts as well (as long as 32 bit libs are installed).
Much here depends on the host. I have tried to hive as much information as possible that the user has a choice. I doubt that it is possible to split the configuration in way that makes it more easy to get the correct settings. It only makes information harder to find.
Any suggestions as to where the documentation may go? I found something here: http://prjemian.github.io/epicspi/ (linked from https://wiki-ext.aps.anl.gov/epics/index.php/HowTo_Documents). It says: "EPICS Base is very easy to build. The wheezy-raspbian distribution already has all the tools necessary to build EPICS Base. All that is necessary is to define the host architecture and then build it." But it does not say how. And it seems it refers to a native build not a cross build.
I can add an article to https://wiki-ext.aps.anl.gov/epics about how to cross compile for raspberry pi. (If you create a login for me). Then all this information including an the example config file can go there and we can leave this here out of EPICS base.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/367256
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Timo Korhonen via Core-talk
[Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: Excessive scan times for periodic scans Konrad, Martin via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Timo Korhonen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Andrew Johnson via Core-talk
ANJ, 14 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
