2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1722535] Re: 'make distclean' inside a submodule
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 13 May 2019 22:37:27 -0000
This was fixed with e92a9ae and included in the 7.0.2.2 release
** Changed in: epics-base
       Status: Confirmed => Fix Committed
     Assignee: (unassigned) => Andrew Johnson (anj)
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1722535
Title:
Status in EPICS Base:
  Fix Released
Bug description:
  Running 'make distclean' inside a base-7.0 submodule deletes the
  parent module's bin and lib directories. Not a major problem, but a
  little unfriendly and unexpected:
  woz$ git st
  On branch libcom/master
  Your branch is up-to-date with 'origin/libcom/master'.
  nothing to commit, working directory clean
  woz$ make distclean
  /Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./configure realclean
  rm -rf O.*
  /Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./src realclean
  rm -rf O.*
  /Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./RTEMS realclean
  rm -rf O.*
  /Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./test realclean
  rm -rf O.*
  perl -CSD /Users/anj/Software/epics/base-7.0/bin/darwin-x86/cvsclean.pl
  rm -rf ./../../dbd ./../../include ./../../doc ./../../html ./../../templates ./../../db ./../../adl ./../../alh ./../../cfg ./../../edl ./../../lib/perl ./../../lib/pkgconfig ./../../configure
  rm -rf ./../../bin
  rm -rf ./../../lib
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1722535/+subscriptions
Prev: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Andrew Johnson via Core-talk
Next: [Bug 1828900] [NEW] dbUnitTest::testdbRecordPtr() is easy to mis-use Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to stable : epics-7.0 » linux32 #128 APS Jenkins via Core-talk
Next: Re: [Bug 1722535] Re: 'make distclean' inside a submodule Andrew Johnson via Core-talk
ANJ, 13 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
