Subject: |
Re: [Bug 1722535] Re: 'make distclean' inside a submodule |
Andrew Johnson via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 13 May 2019 23:11:59 -0000 |
Hi Mark,
On 5/13/19 5:57 PM, Mark Rivers wrote:
Running 'make distclean' inside a base-7.0 submodule deletes the parent
module's bin and lib directories. Not a major problem, but a little
unfriendly and unexpected:
It also deleted the parent module's configure directory, right? I think
that was a more serious problem, since there can be local edits there to
add new ARCHs, etc.
True, although I might not have known that when I wrote the original description for this bug report. Anyway that's all fixed in 7.0.2.2 which completely disables the dangerous targets from RULES_TOP when building a sub-module:
tux% cd modules/database/
tux% make uninstall
/local/anj/base-7.0/configure/RULES_TOP:66: *** Target 'uninstall' not available in a submodule. Stop.
tux% make help
Usage: gnumake [options] [target] ...
Targets supported by all Makefiles:
all - Same as install (default rule)
inc - Installs header files
build - Builds and installs all targets
install - Builds and installs all targets
buildInstall - Same as install (deprecated)
clean - Removes the O.<arch> dirs created by running make
In O.<arch> dir, clean removes build created files
realclean - Removes ALL O.<arch> dirs
Cannot be used within an O.<arch> dir
rebuild - Same as clean install
archclean - Removes O.<arch> dirs but not O.Common dir
depclean - Removes .d files from all O.<arch> dirs.
cvsclean - Removes backup files etc. from all dirs below
runtests - Run self-tests, summarize results immediately
tapfiles - Run self-tests, save to O.<arch>/*.tap files
test-results - Summarize all O.<arch>/*.tap files
clean-tests - Removes all O.<arch>/*.tap files
"Partial" build targets supported by Makefiles:
host - Builds and installs linux-x86_64 only.
inc.<arch> - Installs <arch> only header files.
build.<arch> - Builds and installs <arch> only.
install.<arch> - Builds and installs <arch> only.
clean.<arch> - Cleans <arch> binaries in O.<arch> dirs only.
Targets supported by top level Makefile:
help - Prints this list of valid make targets
Object targets are supported by the O.<arch> level Makefile .e.g
xxxRecord.o
- Andrew
Complexity comes for free, Simplicity you have to work for.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1722535
Title:
Status in EPICS Base:
Fix Released
Bug description:
parent module's bin and lib directories. Not a major problem, but a
little unfriendly and unexpected:
woz$ git st
On branch libcom/master
Your branch is up-to-date with 'origin/libcom/master'.
nothing to commit, working directory clean
woz$ make distclean
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./configure realclean
rm -rf O.*
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./src realclean
rm -rf O.*
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./RTEMS realclean
rm -rf O.*
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./test realclean
rm -rf O.*
perl -CSD /Users/anj/Software/epics/base-7.0/bin/darwin-x86/cvsclean.pl
rm -rf ./../../dbd ./../../include ./../../doc ./../../html ./../../templates ./../../db ./../../adl ./../../alh ./../../cfg ./../../edl ./../../lib/perl ./../../lib/pkgconfig ./../../configure
rm -rf ./../../bin
rm -rf ./../../lib
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1722535/+subscriptions
[Bug 1828900] [NEW] dbUnitTest::testdbRecordPtr() is easy to mis-use Andrew Johnson via Core-talk
Re: Excessive scan times for periodic scans Konrad, Martin via Core-talk
<2019>
2025
2026
[Bug 1722535] Re: 'make distclean' inside a submodule Andrew Johnson via Core-talk
<2019>
2025
2026
