2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1828900] [NEW] dbUnitTest::testdbRecordPtr() is easy to mis-use
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 13 May 2019 22:51:44 -0000
Public bug reported:
There can be a mis-match between the record type expected and the type
of the record returned, but a typical use of testdbRecordPtr() will cast
the pointer to the expected type with no warnings produced if it's
wrong, and any test code that accesses a record-specific field will
likely be pointing at the wrong address.
It should be possible to define a new macro in dbUnitTest.h and an
associated helper function that takes the expected record type as an
argument and checks that the type returned matches the one expected,
returning a pointer that is already cast to the expected type. It should
call testAbort() if the wrong record type is found.
** Affects: epics-base
     Importance: Wishlist
         Status: New
** Tags: codeathon
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1828900
Title:
Status in EPICS Base:
  New
Bug description:
  cast the pointer to the expected type with no warnings produced if
  it's wrong, and any test code that accesses a record-specific field
  will likely be pointing at the wrong address.
  should call testAbort() if the wrong record type is found.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1828900/+subscriptions
Prev: [Bug 1722535] Re: 'make distclean' inside a submodule Andrew Johnson via Core-talk
Next: Re: [Bug 1722535] Re: 'make distclean' inside a submodule Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Bug 1722535] Re: 'make distclean' inside a submodule Andrew Johnson via Core-talk
Next: _WIN32_WINNT defines in EPICS base Freddie Akeroyd - UKRI STFC via Core-talk
ANJ, 15 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
