I was recently compiling EPICS base 3.15 for an earlier windows version from Windows 10 and had a compile error with the WIN32 base implementation of SetThreadName.cpp. The file always sets _WIN32_WINNT to 0x400 (Specifying Windows NT
4.0, the comment says it is dropping support for W95!) which then conflicted with my setting of NTDDI_VERSION. The _WIN32_WINNT macro is also set to 0x400 in osdMutex.c and osdThread.c but in these files it is only set if not otherwise defined externally.
A similar check for an existing definition in SetThreadName.cpp would avoid my compile issue, but as Windows 95 and NT 4.0 are long in the past I wonder if removing these redefinitions of _WIN32_WINNT from base would now be appropriate
Freddie
- Re: _WIN32_WINNT defines in EPICS base Johnson, Andrew N. via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0 Dirk Zimoch via Core-talk
Re: Excessive scan times for periodic scans Konrad, Martin via Core-talk
<2019>
2025
2026
[Bug 1828900] [NEW] dbUnitTest::testdbRecordPtr() is easy to mis-use Andrew Johnson via Core-talk
<2019>
2025
2026
ANJ, 15 May 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
