2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Mon, 20 May 2019 23:05:21 -0000
> Concurrent calls from different threads will see different scopes. However, nested calls within the same thread will see the same scope.
Oh, I didn't notice that. There are calls to macPushScope(handle) and macPopScope(handle) in iocshBody() which create a scope for each shell script or command, and which reset the variables given in iocshRun at the end of that sub-script. I would expect an "on error .." command to expire at exactly the same time as the variable scope.
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/366876
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 mdavidsaver via Core-talk
Prev: [Merge] ~info-martin-konrad/epics-base:dont-nuke-global-cac-thread-id-in-exit-handler into epics-base:3.15 Andrew Johnson via Core-talk
Next: Jenkins build is still unstable: epics-7.0 » linux64 #130 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 Keenan Lang via Core-talk
ANJ, 23 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
