2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Sat, 08 Jun 2019 06:17:34 -0000
Since you changed it to fail soft, the release note needs updating to match. The wording of the second list bullet item is now wrong, and the end of the preceding text paragraph might need tweaking as well, not sure about that.
https://code.launchpad.net/~epics-core/epics-base/+git/asLib/+merge/358822
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: [Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15 Andrew Johnson via Core-talk
Next: epicsThreadSleep and epicsThreadSleepQuantum Konrad, Martin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 23 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
