2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Sat, 08 Jun 2019 06:05:03 -0000
Review: Approve
I don't see any obvious problems with these changes, although I haven't actually tried them. Compilers sure are getting picky nowadays...
https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+merge/366496
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
[Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15 Martin Konrad via Core-talk
Prev: [Merge] ~anj/epics-base/+git/base-3.15:vxworks-tz-support into epics-base:3.15 Andrew Johnson via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15 Martin Konrad via Core-talk
Next: Re: [Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15 mdavidsaver via Core-talk
ANJ, 24 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
