Subject: |
[Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15 |
Martin Konrad via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 25 Apr 2019 02:55:32 -0000 |
Martin Konrad has proposed merging ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+merge/366496
Fix a bunch of compiler warnings.
Your team EPICS Core Developers is requested to review the proposed merge of ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15.
diff --git a/src/libCom/log/iocLogServer.c b/src/libCom/log/iocLogServer.c
index f42aa45..e707185 100644
--- a/src/libCom/log/iocLogServer.c
+++ b/src/libCom/log/iocLogServer.c
@@ -37,7 +37,7 @@
static unsigned short ioc_log_port;
static long ioc_log_file_limit;
-static char ioc_log_file_name[256];
+static char ioc_log_file_name[512];
static char ioc_log_file_command[256];
@@ -866,7 +866,12 @@ static int setupSIGHUP(struct ioc_log_server *pserver)
static void sighupHandler(int signo)
- (void) write(sighupPipe[1], "SIGHUP\n", 7);
+ const char msg[] = "SIGHUP\n";
+ const ssize_t bytesWritten = write(sighupPipe[1], msg, sizeof(msg));
+ if (bytesWritten != sizeof(msg)) {
+ fprintf(stderr, "iocLogServer: failed to write to SIGHUP pipe because "
+ "`%s'\n", strerror(errno));
@@ -884,7 +889,10 @@ static void serviceSighupRequest(void *pParam)
* Read and discard message from pipe.
- (void) read(sighupPipe[0], buff, sizeof buff);
+ if (read(sighupPipe[0], buff, sizeof buff) <= 0) {
+ fprintf(stderr, "iocLogServer: failed to read from SIGHUP pipe because "
* Determine new log file name.
diff --git a/src/std/rec/boRecord.c b/src/std/rec/boRecord.c
index 8818455..48cc484 100644
--- a/src/std/rec/boRecord.c
+++ b/src/std/rec/boRecord.c
@@ -329,9 +329,9 @@ static long get_enum_strs(DBADDR *paddr,struct dbr_enumStrs *pes)
/*SETTING no_str=0 breaks channel access clients*/
pes->no_str = 2;
memset(pes->strs,'\0',sizeof(pes->strs));
- strncpy(pes->strs[0],prec->znam,sizeof(prec->znam));
+ strncpy(pes->strs[0],prec->znam,sizeof(pes->strs[0]));
if(*prec->znam!=0) pes->no_str=1;
- strncpy(pes->strs[1],prec->onam,sizeof(prec->onam));
+ strncpy(pes->strs[1],prec->onam,sizeof(pes->strs[1]));
if(*prec->onam!=0) pes->no_str=2;
return(0);
diff --git a/src/std/rec/stateRecord.c b/src/std/rec/stateRecord.c
index a052b07..8170de7 100644
--- a/src/std/rec/stateRecord.c
+++ b/src/std/rec/stateRecord.c
@@ -98,7 +98,7 @@ static void monitor(stateRecord *prec)
monitor_mask = recGblResetAlarms(prec);
if(strncmp(prec->oval,prec->val,sizeof(prec->val))) {
db_post_events(prec,&(prec->val[0]),monitor_mask|DBE_VALUE|DBE_LOG);
- strncpy(prec->oval,prec->val,sizeof(prec->val));
+ strncpy(prec->oval,prec->val,sizeof(prec->oval));
return;
diff --git a/src/std/rec/stringinRecord.c b/src/std/rec/stringinRecord.c
index db2f626..aac7d4e 100644
--- a/src/std/rec/stringinRecord.c
+++ b/src/std/rec/stringinRecord.c
@@ -120,7 +120,7 @@ static long init_record(stringinRecord *prec, int pass)
if( pdset->init_record ) {
if((status=(*pdset->init_record)(prec))) return(status);
- strncpy(prec->oval, prec->val, sizeof(prec->val));
+ strncpy(prec->oval, prec->val, sizeof(prec->oval));
return(0);
@@ -160,7 +160,7 @@ static void monitor(stringinRecord *prec)
if (strncmp(prec->oval, prec->val, sizeof(prec->val))) {
monitor_mask |= DBE_VALUE | DBE_LOG;
if (prec->mpst == stringinPOST_Always)
diff --git a/src/std/rec/stringoutRecord.c b/src/std/rec/stringoutRecord.c
index 2bca322..61d88f6 100644
--- a/src/std/rec/stringoutRecord.c
+++ b/src/std/rec/stringoutRecord.c
@@ -122,7 +122,7 @@ static long init_record(stringoutRecord *prec, int pass)
return(0);
@@ -188,7 +188,7 @@ static void monitor(stringoutRecord *prec)
if (prec->mpst == stringoutPOST_Always)
- Re: [Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15 Andrew Johnson via Core-talk
- Re: [Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15 mdavidsaver via Core-talk
- [Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15 noreply--- via Core-talk
ICALEPCS 2019 Contributions Johnson, Andrew N. via Core-talk
Re: ICALEPCS 2019 Contributions Timo Korhonen via Core-talk
<2019>
2025
2026
Re: ICALEPCS 2019 Contributions Konrad, Martin via Core-talk
<2019>
2025
2026
