2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsThreadSleep and epicsThreadSleepQuantum
From: Michael Davidsaver via Core-talk <[email protected]>
To: Mark Rivers <[email protected]>, "'Konrad, Martin'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 12 Jun 2019 09:50:58 -0700
On 6/11/19 6:57 AM, Mark Rivers via Core-talk wrote:
>> If we want to sleep for a minimum amount of time we might want to call nanosleep(0) instead.
> But that will not work on Windows or vxWorks.
> Mark
> -----Original Message-----
> From: Konrad, Martin <[email protected]>
> Sent: Tuesday, June 11, 2019 8:49 AM
> To: Mark Rivers <[email protected]>; [email protected]
> Hi,
>> I started a tech-talk thread on this topic 11 years ago:
>> https://epics.anl.gov/tech-talk/2008/msg00987.php
> Thanks Mark, I wasn't aware of this thread. I'm not aware of any way to detect the sleep quantum reliably on modern machines either. The fact that epicsThreadSleepQuantum() only works correctly on old machines without high resolution timers suggests that we should avoid using it. I think it would make sense to
I'll second this.  Minimum sleep time is not a meaningful concept for a modern general purpose OS.
https://en.wikipedia.org/wiki/Tickless_kernel
All the usages of sleep(0) I've seen have been shortcuts to avoid using real synchronization primitives.
This is something I would discourage.
> a) Add a warning to the App Dev Guide.
> b) Consider marking epicsThreadSleepQuantum(), timerQueueActive::quantum(), and fdManager::quantum() as deprecated.
I'd be fine with this, provided all internal usages can be removed.
> c) Remove the "(ppsl->period < 2 * quantum)" part of the test in [1].
There is also a usage in timer::privateStart() to bias expiration time.
I wonder if this tweak is still relevant?
>    this->exp = expire - ( this->queue.notify.quantum () / 2.0 );
https://github.com/epics-base/epics-base/blob/655c5bed925137619d4a538f7893400b38c7c907/modules/libcom/src/timer/timer.cpp#L69
originally introduced by:
https://github.com/epics-base/epics-base/commit/0792aebf952dbc4f7e7291e6175c27b72a80c338
The remaining usage I find in Base, outside of test code, is in various epicsThreadOnce()
implementations which spin to avoid coupling, or copying, the internals of osdEvent.c into osdThread.c.
> nanosleep(0) instead. If I'm understanding the man page correctly this should result at least in a context switch.
Maybe add a dedicated call?
> /* Ensure your epicsThread is fresh and ready to start the day */
> void epicsSnooze();
Re: epicsThreadSleep and epicsThreadSleepQuantum Mark Rivers via Core-talk
Re: epicsThreadSleep and epicsThreadSleepQuantum Johnson, Andrew N. via Core-talk
epicsThreadSleep and epicsThreadSleepQuantum Konrad, Martin via Core-talk
Re: epicsThreadSleep and epicsThreadSleepQuantum Konrad, Martin via Core-talk
RE: epicsThreadSleep and epicsThreadSleepQuantum Mark Rivers via Core-talk
Prev: Re: EPICS 7 PVA for Java Kasemir, Kay via Core-talk
Next: Re: epicsThreadSleep and epicsThreadSleepQuantum Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: RE: epicsThreadSleep and epicsThreadSleepQuantum Mark Rivers via Core-talk
ANJ, 13 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
