Subject: |
Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 |
Andrew Johnson via Core-talk <[email protected]> |
To: |
mdavidsaver <[email protected]> |
Date: |
Mon, 17 Jun 2019 20:55:28 -0000 |
I was thinking that a timeout would at least allow unit test programs to call testAbort() in the event that their threads don't die due to some other bug — this API might turn out to be more useful in unit tests than inside the IOC or other applications, and this could simplify making them more robust against not exiting properly.
I'm starting to think that calling cantProceed() instead of returning an error status might be a mistake, and as I suggested we can always add an epicsThreadMustJoin() routine for those applications that want that behavior. You have already had to change some of our older APIs that only returned void, it would be good to not make that mistake again.
VxWorks 6.8 and earlier still define EPICS_THREAD_CAN_JOIN (0)...
I would start with checks of the basic functionality, and that things the APIs are supposed to reject get rejected (such as self-calling epicsThreadJoin(epicsThreadGetIdSelf()) or on an unjoinable thread; Posix says you can't call pthread_detach() twice, etc. I agree that you probably can't check for resources being freed, but you could check timeout functionality...
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/361379
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 mdavidsaver via Core-talk
Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 Martin Konrad via Core-talk
<2019>
2025
2026
<2019>
2025
2026
