2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Thu, 20 Jun 2019 22:53:50 -0000
The VxWorks implementation of osdThread is pretty thin — our thread ID is the OS's task ID, and in various places the code assumes the system is UP, so no memory barriers are required. I don't understand where else you could see races or user-after-frees that don't also exist in the native taskWait() API. Wind River implements taskWait() by adding the calling task to a wait queue that lives in the TCB of the task being waited for. The queue gets flushed (by a different task) to wake up all waiters when the task is deleted.
Now I agree that the current code is too simple since it doesn't check the status returned by taskWait() or look at errno, which obviously needs to be done and the subsequent behavior made to match the other implementations. I skipped doing that to have the discussion about returning an error status.
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/361379
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: IOC Threads blocking all signals William Norum via Core-talk
Next: [Bug 608956] Re: vxWorks 6.8 deprecates the use of taskVarLib Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 23 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
