2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bhill/epics-base:pvAccess-envDefs.h into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: Bruce Hill <[email protected]>
Date: Tue, 25 Jun 2019 02:05:43 -0000
pvAccessCPP will now use these parameters.
However, I'm having second (third?) thoughts about the idea of having a second or third set of default values for these parameters, which are sometimes are used, and sometimes ignored.
Probably the most confusing is EPICS_PVAS_PROVIDER_NAMES.  A default value of "local" will actually prevent QSRV from starting!  ("local" is the name used by pvDatabaseCPP)  The actual default is "<all>", which selects all registered server-type ChannelProviders.
I'm tempted to say that it would be better to defer to the "pvasr" iocsh function, which can print the configuration actually being used by the running server (in IOCs).
That said, the set of parameters which I think should be advertised are:
EPICS_PVA_ADDR_LIST
EPICS_PVA_AUTO_ADDR_LIST
EPICS_PVA_BROADCAST_PORT
EPICS_PVA_SERVER_PORT
EPICS_PVAS_BEACON_ADDR_LIST
EPICS_PVAS_SERVER_PORT
EPICS_PVAS_INTF_ADDR_LIST
EPICS_PVAS_BROADCAST_PORT
https://code.launchpad.net/~bhill/epics-base/+git/epics-base/+merge/358197
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: [Merge] ~info-martin-konrad/epics-base:clean-up-msi into epics-base:3.15 mdavidsaver via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-7.0:fix-1824277 into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~bhill/epics-base:pvAccess-envDefs.h into epics-base:7.0 Bruce Hill via Core-talk
Next: a question on a commit comment Jeong Han Lee via Core-talk
ANJ, 24 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
