2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-linux32-test #208
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 27 Jun 2019 14:16:19 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32-test/208/display/redirect>
[...truncated 10.05 KB...]
#    - "a = gb2-a  b = gb2-b  c = def-c  d = $(d)\n"
#    - "a = gb3-a  b = gb3-b  c = def-c  d = $(d)\n"
#    - "a = pt1-a  b = gb3-b  c = def-c  d = $(d)\n"
#    - "a = pt2-a  b = pt2-b  c = def-c  d = $(d)\n"
#    - "a = pt3-a  b = pt3-b  c = pt3-c  d = $(d)\n"
#    - "a = pt4-a  b = pt4-b  c = def-c  d = $(d)\n"
#    - "a = pt5-a  b = gb3-b  c = def-c  d = $(d)\n"
#    - "a = gb4-a  b = gb4-b  c = def-c  d = $(d)\n"
#    - "a = pt1-a  b = gb4-b  c = def-c  d = $(d)\n"
#    - "a = pt5-a  b = gb4-b  c = def-c  d = $(d)\n"
#  msi.t line 23 is: ok(msi('-I. -I.. -S ../t3-substitution.txt'),   slurp('../t3-result.txt'));
# Test 4 got: "" (msi.t at line 26)
#   Expected: "a = va1-a  b = def-b  c = def-c  d = $(d)\na = va2-a  b = va2-b  c = def-c  d = $(d)\na = va3-a  b = va3-b  c = va3-c  d = $(d)\na = va4-a  b = va4-b  c = va3-c  d = $(d)\na = va5-a  b = va4-b  c = va3-c  d = $(d)\na = pt3-a  b = pt3-b  c = pt3-c  d = $(d)\n"
#   Lines 1-1 are missing:
#    - "a = va1-a  b = def-b  c = def-c  d = $(d)\n"
#    - "a = va2-a  b = va2-b  c = def-c  d = $(d)\n"
#    - "a = va3-a  b = va3-b  c = va3-c  d = $(d)\n"
#    - "a = va4-a  b = va4-b  c = va3-c  d = $(d)\n"
#    - "a = va5-a  b = va4-b  c = va3-c  d = $(d)\n"
#  msi.t line 26 is: ok(msi('-g -I.. -S ../t4-substitution.txt'),    slurp('../t4-result.txt'));
# Test 5 got: "" (msi.t at line 29)
#   Expected: "# comment line\na = 111\nb = 222\nc = xx\nd = $(d)\n# comment line\na = aaa\nb = bbb\nc = ccc\nd = $(d)\n# comment line\na = AA\nb = BB\nc = xx\nd = $(d)\n# comment line\na = aaa\nb = bbb\nc = yy\nd = $(d)\n"
#    - "# comment line\n"
#    - "a = 111\n"
#    - "b = 222\n"
#    - "c = xx\n"
#    - "d = $(d)\n"
#    - "a = aaa\n"
#    - "b = bbb\n"
#    - "c = ccc\n"
#    - "d = $(d)\n"
#    - "a = AA\n"
#    - "b = BB\n"
#    - "c = xx\n"
#    - "d = $(d)\n"
#    - "a = aaa\n"
#    - "b = bbb\n"
#    - "c = yy\n"
#    - "d = $(d)\n"
#  msi.t line 29 is: ok(msi('-S ../t5-substitute.txt ../t5-template.txt'), slurp('../t5-result.txt'));
# Test 6 got: "" (msi.t at line 32)
#    - "a = 111\n"
#    - "b = 222\n"
#    - "c = xx\n"
#    - "d = $(d)\n"
#    - "a = aaa\n"
#    - "b = bbb\n"
#    - "c = ccc\n"
#    - "d = $(d)\n"
#    - "a = AA\n"
#    - "b = BB\n"
#    - "c = xx\n"
#    - "d = $(d)\n"
#    - "a = aaa\n"
#    - "b = bbb\n"
#    - "c = yy\n"
#    - "d = $(d)\n"
#  msi.t line 32 is: ok(msi('-S../t6-substitute.txt ../t6-template.txt'), slurp('../t6-result.txt'));
Can't open file t7-output.txt: No such file or directory
../../../../../configure/RULES_BUILD:375: recipe for target 'msi.tap' failed
make[3]: [msi.tap] Error 2 (ignored)
make -C ./std tapfiles
make -C O.linux-x86 -f ../Makefile TOP=../../.. \
    T_A=linux-x86 tapfiles
perl -CSD dbLockTest.t -tap > dbLockTest.tap
make[3]: Nothing to be done for 'tapfiles'.
make -C std/filters/test tapfiles
perl -CSD testdbConvert.t -tap > testdbConvert.tap
perl -CSD epicsThreadPriorityTest.t -tap > epicsThreadPriorityTest.tap
perl -CSD callbackTest.t -tap > callbackTest.tap
make -C O.linux-x86 -f ../Makefile TOP=../../../../.. \
perl -CSD tsTest.t -tap > tsTest.tap
perl -CSD dbndTest.t -tap > dbndTest.tap
make -C std/rec/test tapfiles
perl -CSD epicsThreadPrivateTest.t -tap > epicsThreadPrivateTest.tap
perl -CSD arrTest.t -tap > arrTest.tap
perl -CSD arrayOpTest.t -tap > arrayOpTest.tap
perl -CSD syncTest.t -tap > syncTest.tap
perl -CSD epicsThreadHooksTest.t -tap > epicsThreadHooksTest.tap
perl -CSD analogMonitorTest.t -tap > analogMonitorTest.tap
Starting iocInit
perl -CSD scanEventTest.t -tap > scanEventTest.tap
Starting iocInit
perl -CSD regressTest.t -tap > regressTest.tap
perl -CSD epicsThreadPoolTest.t -tap > epicsThreadPoolTest.tap
perl -CSD epicsExitTest.t -tap > epicsExitTest.tap
perl -CSD epicsTimerTest.t -tap > epicsTimerTest.tap
perl -CSD ringPointerTest.t -tap > ringPointerTest.tap
epicsThreadSetPriority called by non epics thread
perl -CSD ringBytesTest.t -tap > ringBytesTest.tap
perl -CSD epicsEventTest.t -tap > epicsEventTest.tap
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
perl -CSD dbStateTest.t -tap > dbStateTest.tap
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
perl -CSD scanIoTest.t -tap > scanIoTest.tap
Starting iocInit
perl -CSD epicsMutexTest.t -tap > epicsMutexTest.tap
Starting iocInit
Starting iocInit
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
perl -CSD dbChArrTest.t -tap > dbChArrTest.tap
Starting iocInit
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
perl -CSD epicsSpinTest.t -tap > epicsSpinTest.tap
chfConfigParseStart: plugin pvt alloc failed
perl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
perl -CSD testPutGetTest.t -tap > testPutGetTest.tap
perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
perl -CSD macDefExpandTest.t -tap > macDefExpandTest.tap
perl -CSD macLibTest.t -tap > macLibTest.tap
perl -CSD taskwdTest.t -tap > taskwdTest.tap
perl -CSD blockingSockTest.t -tap > blockingSockTest.tap
perl -CSD epicsMessageQueueTest.t -tap > epicsMessageQueueTest.tap
perl -CSD epicsStackTraceTest.t -tap > epicsStackTraceTest.tap
perl -CSD ipAddrToAsciiTest.t -tap > ipAddrToAsciiTest.tap
perl -CSD osiSockTest.t -tap > osiSockTest.tap
+ make -s test-results
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
macLib.tap ...... ok
Menu.tap ........ ok
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Snippets.tap .... ok
Variable.tap .... ok
All tests successful.
Files=12, Tests=230,  0 wallclock secs ( 0.20 usr  0.06 sys +  0.01 cusr  0.03 csys =  0.30 CPU)
Result: PASS
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsEnvUnsetTest.tap ........ ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
Files=39, Tests=2900,  1 wallclock secs ( 1.43 usr  0.20 sys +  0.04 cusr  0.11 csys =  1.78 CPU)
Result: PASS
dbShutdownTest.tap ........... ok
dbPutLinkTest.tap ............ ok
dbLockTest.tap ............... ok
testdbConvert.tap ............ ok
callbackTest.tap ............. ok
callbackParallelTest.tap ..... ok
dbStateTest.tap .............. ok
dbCaStatsTest.tap ............ ok
scanIoTest.tap ............... ok
dbChannelTest.tap ............ ok
dbChArrTest.tap .............. ok
chfPluginTest.tap ............ ok
arrShorthandTest.tap ......... ok
recGblCheckDeadbandTest.tap .. ok
testPutGetTest.tap ........... ok
Files=15, Tests=2071,  1 wallclock secs ( 0.99 usr  0.08 sys +  0.01 cusr  0.04 csys =  1.12 CPU)
Result: PASS
msi.tap ..
not ok 1
not ok 2
not ok 3
not ok 4
not ok 5
not ok 6
Failed 12/12 subtests
Test Summary Report
msi.tap (Wstat: 0 Tests: 6 Failed: 6)
  Failed tests:  1-6
  Parse errors: Bad plan.  You planned 12 tests but ran 6.
Files=1, Tests=6,  0 wallclock secs ( 0.07 usr +  0.01 sys =  0.08 CPU)
Result: FAIL
../../../../../configure/RULES_BUILD:354: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 1
../../../../configure/RULES_ARCHS:58: recipe for target 'test-results.linux-x86' failed
make[2]: *** [test-results.linux-x86] Error 2
../configure/RULES_DIRS:84: recipe for target 'ioc/dbtemplate/test.test-results' failed
make[1]: *** [ioc/dbtemplate/test.test-results] Error 2
configure/RULES_DIRS:84: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.linux-x86/*.tap
Saving reports...
Not all test cases were executed according to the test set plan. Marking build as UNSTABLE
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
Jenkins build is back to normal : epics-base-3.15-linux32-test #209 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-base-3.15-mac-test #234 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-3.15-win32-test #218 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.15-mac-test #235 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-3.15-linux32-test #209 APS Jenkins via Core-talk
ANJ, 27 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
