2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-mac-test #234
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 27 Jun 2019 14:09:06 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/234/display/redirect>
[...truncated 10.89 KB...]
perl -CSD epicsSockResolveTest.t -tap > epicsSockResolveTest.tap
perl -CSD epicsStringTest.t -tap > epicsStringTest.tap
perl -CSD epicsTimeTest.t -tap > epicsTimeTest.tap
make[3]: Nothing to be done for 'tapfiles'.
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ioc/O.darwin-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ioc'>
make -C ca/legacy/pcas/ex tapfiles
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ca/legacy/pcas/ex'>
make -C O.darwin-x86 -f ../Makefile TOP=../../../../../.. \
    T_A=darwin-x86 tapfiles
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ca/legacy/pcas/ex/O.darwin-x86'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ca/client/perl/O.darwin-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ca/client/perl'>
make -C ioc/db/test tapfiles
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ioc/db/test'>
make -C O.darwin-x86 -f ../Makefile TOP=../../../../.. \
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ioc/db/test/O.darwin-x86'>
perl -CSD dbShutdownTest.t -tap > dbShutdownTest.tap
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ca/legacy/pcas/ex/O.darwin-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ca/legacy/pcas/ex'>
make -C ioc/dbtemplate/test tapfiles
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ioc/dbtemplate/test'>
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ioc/dbtemplate/test/O.darwin-x86'>
perl -CSD msi.t -tap > msi.tap
# Test 1 got: "" (msi.t at line 17)
#   Expected: "This is t1-template.txt\n\nWith $(a) & $(b):\nThis is t1-include.txt \n  a = default value used when a is undefined\n  b = default value used when b is undefined\nEnd of t1-include.txt\n\nOn defining a=aaa & b=bbb:\nThis is t1-include.txt again\n  a = aaa\n  b = bbb\nEnd of t1-include.txt\n\nOn setting a=\"aa\":\nThis is t1-include.txt again\n  a = \"aa\"\n  b = bbb\nEnd of t1-include.txt\n\nEnd of t1-template.txt\n"
#     (Install the Algorithm::Diff module to have differences in multiline
#      output explained.  You might also set the PERL_TEST_DIFF environment
#      variable to run a diff program on the output.)
#  msi.t line 17 is: ok(msi('-I .. ../t1-template.txt'),             slurp('../t1-result.txt'));
# Test 2 got: "" (msi.t at line 20)
#   Expected: "a = va1-a  b = def-b  c = def-c  d = $(d)\na = va2-a  b = va2-b  c = def-c  d = $(d)\na = va3-a  b = va3-b  c = va3-c  d = $(d)\na = va4-a  b = va4-b  c = def-c  d = $(d)\na = va5-a  b = def-b  c = def-c  d = $(d)\na = pt3-a  b = pt3-b  c = pt3-c  d = $(d)\n"
#  msi.t line 20 is: ok(msi('-I.. -S ../t2-substitution.txt'),       slurp('../t2-result.txt'));
# Test 3 got: "" (msi.t at line 23)
#   Expected: "a = gb1-a  b = gb1-b  c = def-c  d = $(d)\na = va1-a  b = gb1-b  c = def-c  d = $(d)\na = va2-a  b = va2-b  c = def-c  d = $(d)\na = va3-a  b = va3-b  c = va3-c  d = $(d)\na = va4-a  b = va4-b  c = def-c  d = $(d)\na = va5-a  b = gb1-b  c = def-c  d = $(d)\na = gb1-a  b = gb1-b  c = def-c  d = $(d)\na = gb2-a  b = gb2-b  c = def-c  d = $(d)\na = va1-a  b = gb2-b  c = def-c  d = $(d)\na = va2-a  b = va2-b  c = def-c  d = $(d)\na = va3-a  b = va3-b  c = va3-c  d = $(d)\na = va4-a  b = va4-b  c = def-c  d = $(d)\na = va5-a  b = gb2-b  c = def-c  d = $(d)\na = gb2-a  b = gb2-b  c = def-c  d = $(d)\na = gb3-a  b = gb3-b  c = def-c  d = $(d)\na = pt1-a  b = gb3-b  c = def-c  d = $(d)\na = pt2-a  b = pt2-b  c = def-c  d = $(d)\na = pt3-a  b = pt3-b  c = pt3-c  d = $(d)\na = pt4-a  b = pt4-b  c = def-c  d = $(d)\na = pt5-a  b = gb3-b  c = def-c  d = $(d)\na = gb3-a  b = gb3-b  c = def-c  d = $(d)\na = gb4-a  b = gb4-b  c = def-c  d = $(d)\na = pt1-a  b = gb4-b  c = def-c  d = $(d)\na = pt2-a  b = pt2-b  c = def-c  d = $(d)\na = pt3-a  b = pt3-b  c = pt3-c  d = $(d)\na = pt4-a  b = pt4-b  c = def-c  d = $(d)\na = pt5-a  b = gb4-b  c = def-c  d = $(d)\na = gb4-a  b = gb4-b  c = def-c  d = $(d)\n"
#  msi.t line 23 is: ok(msi('-I. -I.. -S ../t3-substitution.txt'),   slurp('../t3-result.txt'));
# Test 4 got: "" (msi.t at line 26)
#   Expected: "a = va1-a  b = def-b  c = def-c  d = $(d)\na = va2-a  b = va2-b  c = def-c  d = $(d)\na = va3-a  b = va3-b  c = va3-c  d = $(d)\na = va4-a  b = va4-b  c = va3-c  d = $(d)\na = va5-a  b = va4-b  c = va3-c  d = $(d)\na = pt3-a  b = pt3-b  c = pt3-c  d = $(d)\n"
#  msi.t line 26 is: ok(msi('-g -I.. -S ../t4-substitution.txt'),    slurp('../t4-result.txt'));
# Test 5 got: "" (msi.t at line 29)
#   Expected: "# comment line\na = 111\nb = 222\nc = xx\nd = $(d)\n# comment line\na = aaa\nb = bbb\nc = ccc\nd = $(d)\n# comment line\na = AA\nb = BB\nc = xx\nd = $(d)\n# comment line\na = aaa\nb = bbb\nc = yy\nd = $(d)\n"
#  msi.t line 29 is: ok(msi('-S ../t5-substitute.txt ../t5-template.txt'), slurp('../t5-result.txt'));
# Test 6 got: "" (msi.t at line 32)
#  msi.t line 32 is: ok(msi('-S../t6-substitute.txt ../t6-template.txt'), slurp('../t6-result.txt'));
Can't open file t7-output.txt: No such file or directory
../../../../../configure/RULES_BUILD:375: recipe for target 'msi.tap' failed
make[3]: [msi.tap] Error 2 (ignored)
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ioc/dbtemplate/test/O.darwin-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ioc/dbtemplate/test'>
make -C ./std tapfiles
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std'>
make -C O.darwin-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std/O.darwin-x86'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std/O.darwin-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std'>
make -C std/filters/test tapfiles
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std/filters/test'>
perl -CSD dbPutLinkTest.t -tap > dbPutLinkTest.tap
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std/filters/test/O.darwin-x86'>
perl -CSD tsTest.t -tap > tsTest.tap
perl -CSD dbndTest.t -tap > dbndTest.tap
log client: connected to log server at "127.0.0.1:50130"
perl -CSD arrTest.t -tap > arrTest.tap
make -C std/rec/test tapfiles
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std/rec/test'>
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std/rec/test/O.darwin-x86'>
perl -CSD syncTest.t -tap > syncTest.tap
perl -CSD arrayOpTest.t -tap > arrayOpTest.tap
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std/filters/test/O.darwin-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std/filters/test'>
perl -CSD epicsTimeZoneTest.t -tap > epicsTimeZoneTest.tap
perl -CSD dbLockTest.t -tap > dbLockTest.tap
perl -CSD analogMonitorTest.t -tap > analogMonitorTest.tap
Starting iocInit
perl -CSD scanEventTest.t -tap > scanEventTest.tap
perl -CSD testdbConvert.t -tap > testdbConvert.tap
Starting iocInit
perl -CSD epicsThreadTest.t -tap > epicsThreadTest.tap
perl -CSD callbackTest.t -tap > callbackTest.tap
perl -CSD regressTest.t -tap > regressTest.tap
perl -CSD epicsThreadOnceTest.t -tap > epicsThreadOnceTest.tap
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std/rec/test/O.darwin-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/std/rec/test'>
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
perl -CSD epicsThreadPriorityTest.t -tap > epicsThreadPriorityTest.tap
perl -CSD dbStateTest.t -tap > dbStateTest.tap
perl -CSD epicsThreadPrivateTest.t -tap > epicsThreadPrivateTest.tap
perl -CSD epicsThreadHooksTest.t -tap > epicsThreadHooksTest.tap
perl -CSD epicsThreadPoolTest.t -tap > epicsThreadPoolTest.tap
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
perl -CSD epicsExitTest.t -tap > epicsExitTest.tap
perl -CSD epicsTimerTest.t -tap > epicsTimerTest.tap
perl -CSD ringPointerTest.t -tap > ringPointerTest.tap
epicsThreadSetPriority called by non epics thread
perl -CSD scanIoTest.t -tap > scanIoTest.tap
Starting iocInit
Starting iocInit
Starting iocInit
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
perl -CSD dbChArrTest.t -tap > dbChArrTest.tap
Starting iocInit
perl -CSD ringBytesTest.t -tap > ringBytesTest.tap
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
perl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
chfConfigParseStart: plugin pvt alloc failed
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
perl -CSD testPutGetTest.t -tap > testPutGetTest.tap
perl -CSD epicsEventTest.t -tap > epicsEventTest.tap
perl -CSD epicsMutexTest.t -tap > epicsMutexTest.tap
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ioc/db/test/O.darwin-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/ioc/db/test'>
perl -CSD epicsSpinTest.t -tap > epicsSpinTest.tap
perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
perl -CSD macDefExpandTest.t -tap > macDefExpandTest.tap
perl -CSD macLibTest.t -tap > macLibTest.tap
perl -CSD taskwdTest.t -tap > taskwdTest.tap
perl -CSD blockingSockTest.t -tap > blockingSockTest.tap
perl -CSD epicsMessageQueueTest.t -tap > epicsMessageQueueTest.tap
perl -CSD epicsStackTraceTest.t -tap > epicsStackTraceTest.tap
perl -CSD ipAddrToAsciiTest.t -tap > ipAddrToAsciiTest.tap
perl -CSD osiSockTest.t -tap > osiSockTest.tap
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/libCom/test/O.darwin-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src/libCom/test'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/src'>
+ make -s test-results CROSS_COMPILER_TARGET_ARCHS=
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
macLib.tap ...... ok
Menu.tap ........ ok
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Snippets.tap .... ok
Variable.tap .... ok
All tests successful.
Files=12, Tests=230,  1 wallclock secs ( 0.06 usr  0.03 sys +  0.01 cusr  0.00 csys =  0.10 CPU)
Result: PASS
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsEnvUnsetTest.tap ........ ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
Files=39, Tests=2900,  1 wallclock secs ( 0.26 usr  0.06 sys +  0.06 cusr  0.03 csys =  0.41 CPU)
Result: PASS
dbShutdownTest.tap ........... ok
dbPutLinkTest.tap ............ ok
dbLockTest.tap ............... ok
testdbConvert.tap ............ ok
callbackTest.tap ............. ok
callbackParallelTest.tap ..... ok
dbStateTest.tap .............. ok
dbCaStatsTest.tap ............ ok
scanIoTest.tap ............... ok
dbChannelTest.tap ............ ok
dbChArrTest.tap .............. ok
chfPluginTest.tap ............ ok
arrShorthandTest.tap ......... ok
recGblCheckDeadbandTest.tap .. ok
testPutGetTest.tap ........... ok
Files=15, Tests=2071,  1 wallclock secs ( 0.17 usr  0.03 sys +  0.02 cusr  0.01 csys =  0.23 CPU)
Result: PASS
msi.tap ..
not ok 1
not ok 2
not ok 3
not ok 4
not ok 5
not ok 6
Failed 12/12 subtests
Test Summary Report
msi.tap (Wstat: 0 Tests: 6 Failed: 6)
  Failed tests:  1-6
  Parse errors: Bad plan.  You planned 12 tests but ran 6.
Files=1, Tests=6,  0 wallclock secs ( 0.03 usr +  0.00 sys =  0.03 CPU)
Result: FAIL
../../../../../configure/RULES_BUILD:354: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 1
../../../../configure/RULES_ARCHS:58: recipe for target 'test-results.darwin-x86' failed
make[2]: *** [test-results.darwin-x86] Error 2
../configure/RULES_DIRS:84: recipe for target 'ioc/dbtemplate/test.test-results' failed
make[1]: *** [ioc/dbtemplate/test.test-results] Error 2
configure/RULES_DIRS:84: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.darwin-x86/*.tap
Saving reports...
Not all test cases were executed according to the test set plan. Marking build as UNSTABLE
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
Jenkins build is back to normal : epics-base-3.15-mac-test #235 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-base-3.15-test #117 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-linux32-test #208 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.15-test #118 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-3.15-mac-test #235 APS Jenkins via Core-talk
ANJ, 27 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
