2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-test #117
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 27 Jun 2019 14:06:56 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-test/117/display/redirect>
Started by upstream project "epics-base-3.15" build number 426
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building on master in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-test/ws/>
[workspace] $ /bin/sh -xe /tmp/jenkins6952753420970103693.sh
+ make -s clean-tests CROSS_COMPILER_TARGET_ARCHS=
+ make -sj4 junitfiles CROSS_COMPILER_TARGET_ARCHS=
# Test 1 got: "" (msi.t at line 17)
#   Expected: "This is t1-template.txt\n\nWith $(a) & $(b):\nThis is t1-include.txt \n  a = default value used when a is undefined\n  b = default value used when b is undefined\nEnd of t1-include.txt\n\nOn defining a=aaa & b=bbb:\nThis is t1-include.txt again\n  a = aaa\n  b = bbb\nEnd of t1-include.txt\n\nOn setting a=\"aa\":\nThis is t1-include.txt again\n  a = \"aa\"\n  b = bbb\nEnd of t1-include.txt\n\nEnd of t1-template.txt\n"
#   Lines 1-1 are missing:
#    - "This is t1-template.txt\n"
#    - "\n"
#    - "With $(a) & $(b):\n"
#    - "This is t1-include.txt \n"
#    - "  a = default value used when a is undefined\n"
#    - "  b = default value used when b is undefined\n"
#    - "End of t1-include.txt\n"
#    - "\n"
#    - "On defining a=aaa & b=bbb:\n"
#    - "This is t1-include.txt again\n"
#    - "  a = aaa\n"
#    - "  b = bbb\n"
#    - "\n"
#    - "On setting a=\"aa\":\n"
#    - "  a = \"aa\"\n"
#    - "  b = bbb\n"
#    - "\n"
#    - "End of t1-template.txt\n"
#  msi.t line 17 is: ok(msi('-I .. ../t1-template.txt'),             slurp('../t1-result.txt'));
# Test 2 got: "" (msi.t at line 20)
#   Expected: "a = va1-a  b = def-b  c = def-c  d = $(d)\na = va2-a  b = va2-b  c = def-c  d = $(d)\na = va3-a  b = va3-b  c = va3-c  d = $(d)\na = va4-a  b = va4-b  c = def-c  d = $(d)\na = va5-a  b = def-b  c = def-c  d = $(d)\na = pt3-a  b = pt3-b  c = pt3-c  d = $(d)\n"
#    - "a = va1-a  b = def-b  c = def-c  d = $(d)\n"
#    - "a = va2-a  b = va2-b  c = def-c  d = $(d)\n"
#    - "a = va3-a  b = va3-b  c = va3-c  d = $(d)\n"
#    - "a = va4-a  b = va4-b  c = def-c  d = $(d)\n"
#    - "a = va5-a  b = def-b  c = def-c  d = $(d)\n"
#    - "a = pt3-a  b = pt3-b  c = pt3-c  d = $(d)\n"
#  msi.t line 20 is: ok(msi('-I.. -S ../t2-substitution.txt'),       slurp('../t2-result.txt'));
# Test 3 got: "" (msi.t at line 23)
#   Expected: "a = gb1-a  b = gb1-b  c = def-c  d = $(d)\na = va1-a  b = gb1-b  c = def-c  d = $(d)\na = va2-a  b = va2-b  c = def-c  d = $(d)\na = va3-a  b = va3-b  c = va3-c  d = $(d)\na = va4-a  b = va4-b  c = def-c  d = $(d)\na = va5-a  b = gb1-b  c = def-c  d = $(d)\na = gb1-a  b = gb1-b  c = def-c  d = $(d)\na = gb2-a  b = gb2-b  c = def-c  d = $(d)\na = va1-a  b = gb2-b  c = def-c  d = $(d)\na = va2-a  b = va2-b  c = def-c  d = $(d)\na = va3-a  b = va3-b  c = va3-c  d = $(d)\na = va4-a  b = va4-b  c = def-c  d = $(d)\na = va5-a  b = gb2-b  c = def-c  d = $(d)\na = gb2-a  b = gb2-b  c = def-c  d = $(d)\na = gb3-a  b = gb3-b  c = def-c  d = $(d)\na = pt1-a  b = gb3-b  c = def-c  d = $(d)\na = pt2-a  b = pt2-b  c = def-c  d = $(d)\na = pt3-a  b = pt3-b  c = pt3-c  d = $(d)\na = pt4-a  b = pt4-b  c = def-c  d = $(d)\na = pt5-a  b = gb3-b  c = def-c  d = $(d)\na = gb3-a  b = gb3-b  c = def-c  d = $(d)\na = gb4-a  b = gb4-b  c = def-c  d = $(d)\na = pt1-a  b = gb4-b  c = def-c  d = $(d)\na = pt2-a  b = pt2-b  c = def-c  d = $(d)\na = pt3-a  b = pt3-b  c = pt3-c  d = $(d)\na = pt4-a  b = pt4-b  c = def-c  d = $(d)\na = pt5-a  b = gb4-b  c = def-c  d = $(d)\na = gb4-a  b = gb4-b  c = def-c  d = $(d)\n"
#    - "a = gb1-a  b = gb1-b  c = def-c  d = $(d)\n"
#    - "a = va1-a  b = gb1-b  c = def-c  d = $(d)\n"
#    - "a = va5-a  b = gb1-b  c = def-c  d = $(d)\n"
#    - "a = gb2-a  b = gb2-b  c = def-c  d = $(d)\n"
#    - "a = va1-a  b = gb2-b  c = def-c  d = $(d)\n"
#    - "a = va5-a  b = gb2-b  c = def-c  d = $(d)\n"
#    - "a = gb3-a  b = gb3-b  c = def-c  d = $(d)\n"
#    - "a = pt1-a  b = gb3-b  c = def-c  d = $(d)\n"
#    - "a = pt2-a  b = pt2-b  c = def-c  d = $(d)\n"
#    - "a = pt4-a  b = pt4-b  c = def-c  d = $(d)\n"
#    - "a = pt5-a  b = gb3-b  c = def-c  d = $(d)\n"
#    - "a = gb4-a  b = gb4-b  c = def-c  d = $(d)\n"
#    - "a = pt1-a  b = gb4-b  c = def-c  d = $(d)\n"
#    - "a = pt5-a  b = gb4-b  c = def-c  d = $(d)\n"
#  msi.t line 23 is: ok(msi('-I. -I.. -S ../t3-substitution.txt'),   slurp('../t3-result.txt'));
# Test 4 got: "" (msi.t at line 26)
#   Expected: "a = va1-a  b = def-b  c = def-c  d = $(d)\na = va2-a  b = va2-b  c = def-c  d = $(d)\na = va3-a  b = va3-b  c = va3-c  d = $(d)\na = va4-a  b = va4-b  c = va3-c  d = $(d)\na = va5-a  b = va4-b  c = va3-c  d = $(d)\na = pt3-a  b = pt3-b  c = pt3-c  d = $(d)\n"
#    - "a = va4-a  b = va4-b  c = va3-c  d = $(d)\n"
#    - "a = va5-a  b = va4-b  c = va3-c  d = $(d)\n"
#  msi.t line 26 is: ok(msi('-g -I.. -S ../t4-substitution.txt'),    slurp('../t4-result.txt'));
# Test 5 got: "" (msi.t at line 29)
#   Expected: "# comment line\na = 111\nb = 222\nc = xx\nd = $(d)\n# comment line\na = aaa\nb = bbb\nc = ccc\nd = $(d)\n# comment line\na = AA\nb = BB\nc = xx\nd = $(d)\n# comment line\na = aaa\nb = bbb\nc = yy\nd = $(d)\n"
#    - "# comment line\n"
#    - "a = 111\n"
#    - "b = 222\n"
#    - "c = xx\n"
#    - "d = $(d)\n"
#    - "a = aaa\n"
#    - "b = bbb\n"
#    - "c = ccc\n"
#    - "d = $(d)\n"
#    - "a = AA\n"
#    - "b = BB\n"
#    - "c = xx\n"
#    - "d = $(d)\n"
#    - "a = aaa\n"
#    - "b = bbb\n"
#    - "c = yy\n"
#    - "d = $(d)\n"
#  msi.t line 29 is: ok(msi('-S ../t5-substitute.txt ../t5-template.txt'), slurp('../t5-result.txt'));
# Test 6 got: "" (msi.t at line 32)
#    - "a = 111\n"
#    - "b = 222\n"
#    - "c = xx\n"
#    - "d = $(d)\n"
#    - "a = aaa\n"
#    - "b = bbb\n"
#    - "c = ccc\n"
#    - "d = $(d)\n"
#    - "a = AA\n"
#    - "b = BB\n"
#    - "c = xx\n"
#    - "d = $(d)\n"
#    - "a = aaa\n"
#    - "b = bbb\n"
#    - "c = yy\n"
#    - "d = $(d)\n"
#  msi.t line 32 is: ok(msi('-S../t6-substitute.txt ../t6-template.txt'), slurp('../t6-result.txt'));
Can't open file t7-output.txt: No such file or directory
../../../../../configure/RULES_BUILD:379: recipe for target 'msi.xml' failed
make[3]: *** [msi.xml] Error 86
../../../../configure/RULES_ARCHS:58: recipe for target 'junitfiles.linux-x86_64' failed
make[2]: *** [junitfiles.linux-x86_64] Error 2
../configure/RULES_DIRS:84: recipe for target 'ioc/dbtemplate/test.junitfiles' failed
make[1]: *** [ioc/dbtemplate/test.junitfiles] Error 2
make[1]: *** Waiting for unfinished jobs....
log client: connected to log server at "127.0.0.1:60756"
epicsThreadSetPriority called by non epics thread
Starting iocInit
Starting iocInit
Starting iocInit
Starting iocInit
Warning: Duplicate EPICS CA Address list entry "10.8.0.255:5065" discarded
Warning: Duplicate EPICS CA Address list entry "10.8.5.255:5065" discarded
chfConfigParseStart: plugin pvt alloc failed
configure/RULES_DIRS:84: recipe for target 'src.junitfiles' failed
make: *** [src.junitfiles] Error 2
Build step 'Execute shell' marked build as failure
Recording test results
Jenkins build is back to normal : epics-base-3.15-test #118 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-example-win64 #350 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-mac-test #234 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-example-win64 #354 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-3.15-test #118 APS Jenkins via Core-talk
ANJ, 12 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
