On 6/29/19 7:37 AM, Mark Rivers via Core-talk wrote:
> Folks,
> I have an NDArray with a string attribute holding the value “Continuous”. When the NDArray gets converted to an NTNDArray in NTNDArrayConverter I am getting this crash:
> #0 0x00007fad6f64e2ad in () at /lib64/libstdc++.so.6
> #1 0x00007fad6f6b1e5e in std::string::assign(std::string const&) () at /lib64/libstdc++.so.6
> #2 0x00000000006c113d in epics::pvData::detail::ScalarStorageOps<std::string>::store(std::string const&) (__str="Continuous", this=0x7fac14002650)
> at /usr/include/c++/4.8.2/bits/basic_string.h:547
> #3 0x00000000006c113d in epics::pvData::detail::ScalarStorageOps<std::string>::store(std::string const&) (this=this@entry=0x7fac14002650, val="Continuous")
> at /usr/local/epics-devel/base-7.0.2/include/pv/pvData.h:362
> #4 0x00000000006cbf41 in NTNDArrayConverter::fromStringAttribute(std::tr1::shared_ptr<epics::pvData::PVStructure>, NDAttribute*) (v="Continuous", this=0x7fac140025f0)
> at /corvette/usr/local/epics-devel/base-7.0.2/include/pv/pvData.h:399
> #5 0x00000000006cbf41 in NTNDArrayConverter::fromStringAttribute(std::tr1::shared_ptr<epics::pvData::PVStructure>, NDAttribute*) (this=this@entry=0x2fb0130, dest=
> std::tr1::shared_ptr (count 3, weak 1) 0x7fac140020b0, src=src@entry=0x7fabf0001620) at ../ntndArrayConverter.cpp:543
> #6 0x00000000006ccc62 in NTNDArrayConverter::fromAttributes(NDArray*) (this=this@entry=0x2fb0130, src=src@entry=0x7fac94001270) at ../ntndArrayConverter.cpp:589
> #7 0x00000000006cf38d in NTNDArrayConverter::fromArray(NDArray*) (this=0x2fb0130, src=src@entry=0x7fac94001270) at ../ntndArrayConverter.cpp:240
> #8 0x000000000066c578 in NTNDArrayRecord::update(NDArray*) (this=0x2fad910, pArray=0x7fac94001270) at ../NDPluginPva.cpp:85
> #9 0x000000000066c6ad in NDPluginPva::processCallbacks(NDArray*) (this=0x2f6c2a0, pArray=0x7fac94001270) at ../NDPluginPva.cpp:124
> #10 0x000000000066f476 in NDPluginDriver::processTask() (this=0x2f6c2a0) at ../NDPluginDriver.cpp:524
> #11 0x00000000012ac7f9 in epicsThreadCallEntryPoint(void*) (pPvt=0x2f6aff0) at ../../src/osi/epicsThread.cpp:83
> #12 0x00000000012b226c in start_routine (arg=0x2f6aeb0) at ../../src/osi/os/posix/osdThread.c:403
> #13 0x00007fad6ff53e25 in start_thread () at /lib64/libpthread.so.0
> #14 0x00007fad6ee0cbad in clone () at /lib64/libc.so.6
> This is base 7.0.2.2 on linux-x86_64.
> Any idea why this is crashing?
I first suspect static cast in NTNDArrayConverter::fromStringAttribute()
https://github.com/areaDetector/ADCore/blob/44b3a9b62e65f8a8bfb180292f77d08a5e2c4fdd/ADApp/ntndArrayConverterSrc/ntndArrayConverter.cpp#L535-L544
From the logic, this code will break if the union already contains
something which isn't a PVString.
Assuming that the value should always be stored as a string (as opposed
to attempting a conversion). Maybe change to something like:
> std::vector<char> value(attrDataSize); // same as malloc(), with auto-free()
> src->getValue(attrDataType, &value[0], attrDataSize);
> PVUnionPtr destUnion(dest->getSubFieldT<PVUnion>("value")); // note the added T
> PVStringPtr valueFld(destUnion->get<PVString>());
> if(!valueFld) {
> valueFld = PVDC->createPVScalar<PVString>();
> destUnion->put(valueFld);
> value->put(value);
- RE: Crash in pvData Mark Rivers via Core-talk
- Crash in pvData Mark Rivers via Core-talk
<2019>
2025
2026
<2019>
2025
2026
