2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15
From: Freddie Akeroyd via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 12 Jul 2019 15:38:26 -0000
Hi Andrew, I went back to try using fflush myself and now the machine that failed regularly will not fail at all when reverted! I had come across this issue intermittently before and a re-run usually fixed it, I briefly had this one machine doing it regularly but not anymore :-( Going with   fflush(outFP)   over   fclose(outFP)  is fine with me if we have a reproducible test case that it fixes. An   fclose()   will close the underlying windows handle at that point as well as do a flush, the online windows example seems to do this but i don't know if it is important. Given that we know there are no atexit handles or further things with stdout that msi does it should be safe to use fclose() and that would certainly cover everything on windows.
https://code.launchpad.net/~freddie-akeroyd/epics-base/+git/epics-base/+merge/369763
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
[Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Freddie Akeroyd via Core-talk
Prev: Jenkins build is back to normal : epics-example-win64 #354 APS Jenkins via Core-talk
Next: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Freddie Akeroyd via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Andrew Johnson via Core-talk
ANJ, 12 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
