2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 16 Jul 2019 17:45:31 -0000
Freddie, was your machine running Windows 7 or Windows 10? I have just disabled the retries in the unit test code and can't seem to trigger the failures any more (without adding the fflush()), although it may be that running the test program by hand doesn't do it. I probably saw them when I was using Windows 7 though, now I'm running Windows 10 and that might also have fixed the problem.
The opt_D flag is used by the EPICS build system to generate a make dependency rule for the output file. The expected behaviour is supposed to match GCC's -M flag and output the rule to stdout, using the -o argument to provide the name of the target filename to use in the rule. This code was a recent addition, and the author (most likely me) might not have considered the effect of an error that aborts the program. For it to call unlink(outFile) isn't a problem though, it ensures that GNUmake will have to run msi without the -D to (re)generate the output file, which *should* result in the same error and the build stopping.
I'm thinking we should add the flush(stdout), remove the retries from the test program and just wait to see whether we see any more failures.
https://code.launchpad.net/~freddie-akeroyd/epics-base/+git/epics-base/+merge/369763
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
[Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Freddie Akeroyd via Core-talk
Prev: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Freddie Akeroyd via Core-talk
Next: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Freddie Akeroyd via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 16 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
