2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15
From: Freddie Akeroyd via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 15 Jul 2019 22:13:22 -0000
Unfortunately the machine I tested on is no longer showing bad behaviour (it was always transient when i had it, but i had a reproducible failures for a while which fclose fixed). So i think fflush would work, but i'm afraid i can't confirm it with an actual test.
With regard to using fopen, if opt_D is specified then outFile is not opened for output but appears to have its name written to stdout, so fclose(outFP) wold then be fclose(stdout) but also abortExit() would do an
unlink(outFile) which didn't feel right, but i wondered if this was the desired behaviour by how it was usually called. The unlink(outFile) on an error is present in the existing code, I pushed and then reverted a test on opt_D as I though I should check if that was intentional with somebody first.
https://code.launchpad.net/~freddie-akeroyd/epics-base/+git/epics-base/+merge/369763
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
[Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Freddie Akeroyd via Core-talk
Prev: Jenkins build became unstable: epics-pva2pva-linux32 #123 APS Jenkins via Core-talk
Next: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Freddie Akeroyd via Core-talk
ANJ, 16 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
