Heinz,
These failures were on Windows, and I'm hoping they're transient. We've just upgraded our Jenkins version which has restarted the build agents on that box, and I'm re-running those tests right now.
- Andrew
On 7/18/19 2:47 AM, Heinz Junkes via Core-talk wrote:
Michael,
is this RTEMS related?
When I started trying to use RTEMS5 with osd/posix I was confronted with exactly this problem.
epicsThreadOnce and epicsThreadPriority issues.
I developed a lot of "cramp constructions" to make it work.
Then Till had built in a modification for "non-epicsThreads may receive wrong priority and crash” (https://bugs.launchpad.net/epics-base/+bug/1816841)
affecting SCHED_FIFO? and my problems with RTEMS were solved with it and I could take away my messed up modifications.
Since then I had no stress anymore with that.
Heinz
On 17. Jul 2019, at 20:32, Michael Davidsaver via Core-talk <[email protected]> wrote:
I can't recall seeing failures in epicsThreadOnceTest or epicsThreadPriorityTest before...
On 7/17/19 11:27 AM, APS Jenkins via Core-talk wrote:
Test Summary Report
epicsMathTest.tap (Wstat: 0 Tests: 35 Failed: 0)
TODO passed: 8-9, 11-12, 22-23
epicsThreadOnceTest.tap (Wstat: 0 Tests: 11 Failed: 2)
Failed tests: 1, 8
epicsThreadPriorityTest.tap (Wstat: 0 Tests: 5 Failed: 1)
Failed test: 3
Parse errors: Bad plan. You planned 7 tests but ran 5.
ipAddrToAsciiTest.tap (Wstat: 0 Tests: 5 Failed: 1)
Failed test: 2
Files=39, Tests=2898, 5 wallclock secs ( 0.61 usr + 0.70 sys = 1.31 CPU)
Result: FAIL
Complexity comes for free, Simplicity you have to work for.
- Build failed in Jenkins: epics-base-3.15-win64-test #234 APS Jenkins via Core-talk
- epicsThreadOnceTest/epicsThreadPriorityTest failures Michael Davidsaver via Core-talk
- Re: epicsThreadOnceTest/epicsThreadPriorityTest failures Heinz Junkes via Core-talk
RE: Message in the epics shell for PointGrey camera, Core R3.6 Mark Rivers via Core-talk
Jenkins build is back to normal : epics-base-3.15-win64-test #237 APS Jenkins via Core-talk
<2019>
2025
2026
Build failed in Jenkins: epics-base-3.15-win64-test #235 APS Jenkins via Core-talk
<2019>
2025
2026
ANJ, 18 Jul 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
