2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: EPICS 7 array link inconsistencies
From: "Zimoch Dirk \(PSI\) via Core-talk" <[email protected]>
Date: Wed, 24 Jul 2019 12:04:49 +0000
Hi everyone,
I found something confusing in the link syntax today when accessing arrays.
field(INP, "$(WF_RECORD).[5] CP") returns the number at index 5
but field(INP, "$(WF_RECORD).[5]") returns the number at index 0
This can be very confusing to the user. It would be nice to have the same array
syntax regardless of the link type, CA or not.
Here is my test db:
record(aai, "$(P)AAI") {
    field(NELM, 10)
    field(INP, [1,2,3,4,5,6,7,8,9,10])
record(ai, "$(P)AI1") {
    field(INP, "$(P)AAI.[5] CP")
    field(PINI, YES)
record(ai, "$(P)AI2") {
    field(INP, "$(P)AAI.[5]")
    field(PINI, YES)
Dirk
Re: EPICS 7 array link inconsistencies Johnson, Andrew N. via Core-talk
Prev: Misleading "initPeriodic: Scan rate ... is not achievable" and sleep quantum implementation Zimoch Dirk (PSI) via Core-talk
Next: Re: Misleading "initPeriodic: Scan rate ... is not achievable" and sleep quantum implementation Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Misleading "initPeriodic: Scan rate ... is not achievable" and sleep quantum implementation Zimoch Dirk (PSI) via Core-talk
Next: Re: EPICS 7 array link inconsistencies Johnson, Andrew N. via Core-talk
ANJ, 25 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
