Hi Bruno,
I'm currently working on generating a new EPICS release, and I just noticed that there is nothing in the normativeTypes Release Notes document about all of the updates you made to the validation code back in May and June. Would you have any time in the next
working day or so to add some notes about your changes to the top of the documentation/RELEASE_NOTES.md file?
I will need to bump the module's version number from 5.2.2; after your changes, should this become 6.0.0 or would 5.3.0 be a better choice? You could just answer that question in Release notes heading you use if you like.
I suspect the file documentation/ntCPP.html may also need some changes to match your updates. I'm not expecting you to work on that at the same time, but I'd appreciate if you could take a quick look at it and assess how much it might need to be modified. If
the changes are trivial and you can do them that would be great, but if not please just include a comment in the Release Notes that the other document has not been updated yet (it already shows an older version and date).
Sorry this request is a bit last-minute.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Re: normativeTypes module in EPICS 7.0.3 Bruno Martins via Core-talk
Re: EPICS 7 array link inconsistencies Zimoch Dirk (PSI) via Core-talk
Re: epics base compilation for ARM Cotex-A53 (ARM64bit) Johnson, Andrew N. via Core-talk
<2019>
2025
2026
[Bug 1392516] Re: OSI monotonic time source Andrew Johnson via Core-talk
<2019>
2025
2026
ANJ, 26 Jul 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
